Power steering flush
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SeniorSpan, Apr 25, 2012.
  1. Apr 25, 2012 at 9:01 AM
    SeniorSpan
    SeniorSpan [OP] Well-Known Member
    Bob
    Colorado Springs
    11 Silver 4wd TRD DC TXpro
    G'day all,
    A friend took his 2009 v6 Tacoma in for 60,000 maint. and dealer recommended " a power steering system flush".
    Had not found that in any maint. schedule nor had it done on any Tacoma I've every owned.
    Is this really a necessary evil or was the dealership "slid'en one by"? (cost $139.)
    Thanks
  2. Apr 25, 2012 at 9:10 AM
    medic2230
    medic2230 Ditch Doctor
    Murph
    Bama! Roll Tide
    2011 Taco 4x4 DCLB
    20% Tint, OME 3"complete lift with Dakar's, Light Racing UCA's, 285/75/16 Nitto Terra Grapplers, 10 HP TW sticker, Ultraguage, B.A.M.F. Rock Sliders, MedicFab Bed Rack, Relentless front bumper
    They pulled the same crap on the 4runner here. I told them I had never heard of doing that and that my 2000 Taco still had the same power steering fluid in it that came with it. They said that the fluid in the 4runner was dark and it was time to change it and flush it. I think they changed something in them either the fluid or something is doing something to the fluid.
  3. Apr 25, 2012 at 9:14 AM
    dusman
    dusman Well-Known Member
    Dustin
    Windsor, Maine
    2017 TRD ORDC MGM
    yes, you should for sure do it, get it done that is cheap. My dealership wanted to flush my windshield wiper fluid for $150 j/k ;)
  4. Apr 25, 2012 at 10:31 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Another option is to skip the flush, but suction out the fluid from the res and just replace that. If you do that every 30k you should be just fine. Kind of like the difference between a trans pan drain and a flush. Your call on how far you want to go.
  5. Apr 25, 2012 at 11:33 AM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    Just suction out your fluid yourself and replace. Flushing is never a good idea imo. For your rack or tranny
  6. Apr 25, 2012 at 11:44 AM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    03 F250 CCSB
    Gibson stainless headers, custom free-flow Y-pipe, Magnaflow muffler, 285/75R16 KBro2's
    As others have said, suction out the reservoir and fill it back up. If you want it to be more complete, do this twice, but in between park on some dirt and turn your wheel lock to lock a dozen times or so.
  7. Apr 25, 2012 at 12:40 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Thats fine but there is always tons of garbage on the bottom of the reservoir. I removed mine to clean. I would suggest the same and its cheap.
  8. Apr 25, 2012 at 12:50 PM
    boshak
    boshak Well-Known Member
    Tony
    Southern California
    2003 Manual 4x4 5VZ-FE
    OME 881's, Wheeler's 5-leaf pack, Bilstein 5100's
    This. Dirt or jack up the front of the truck. I did this myself a few weeks ago.
    Suction, fill with new fluid, start truck and turn wheels lock to lock for a minute or two. Repeat.
  9. Apr 25, 2012 at 6:53 PM
    SeniorSpan
    Bob
    Colorado Springs
    Thanks guys I appreciate your time and the inputs.
  10. Apr 26, 2012 at 2:11 AM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    I flushed and replaced the fluid in my truck at around 20000 miles.
    Removed the fluid return hose from the rezzy, stuck it in a catch bucket, jacked the front end to lighten the weight on wheels. Removed rezzy and rinsed out the debris in the bottom. Reinstalled the rezzy and added a Magnafine filter.
    Did not yet reconnect the return hose.
    Added M1 atf fluid, started truck and kept adding fluid while a helper cycled the steering lock to lock a few times. Ultimately the return fluid was again red. Reconnected the hose to the rezzy.
    Should last a while.
    PK
  11. Jul 4, 2014 at 5:00 PM
    blazze2005
    blazze2005 Well-Known Member
    South Jersey
    05 Tacoma Pre-Runner Sport
    Fuel Off-Road Octane Wheels,Yokohama Geolander ATS 265/65/17.Grillcraft,Borla Exhaust,Truxedo Lo Pro Tonneau Cover,Pop n Lock Tailgate Security,Custom Wet Okle TRD Seat Covers,Catch-All Matts,Gatorback Belt,Shorty Antenna,Toyota Bed Matt,Sirius Radio,Vent Sades,20% Lumar Window Tint
  12. Oct 17, 2015 at 1:51 PM
    beavis87
    beavis87 Well-Known Member
    El Paso
    '10 Silver TRD OR
    Great video. I was pretty confused why some members here warn not to flush but just suction and fill. It seems that you will not get as much old fluid out if you don't flush it like in the video. Sorry for my ignorance but which line is the return line? Also, anyone replace the power steering filter too?
