Power Steering growl
Discussion in '1st Gen. Tacomas (1995-2004)' started by VBdiver58, Jun 1, 2023.
  1. Jun 1, 2023 at 8:01 PM
    VBdiver58
    VBdiver58 [OP] Well-Known Member
    Virginia
    1999 Tacoma xtra cab 4x4 2.7L
    16" Toyota rims
    power steering growls during a sharp low speed turn . mostly a left turn say across traffic , into a driveway etc.. only if I rush the turn does noise appear .
    If I stop engine and restart the growl goes away .
    I did the flush with turkey baster method . Local mechanic did a total flush .
    any thoughts ?
  2. Jun 1, 2023 at 9:39 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    That would put the most load on the pump... I'd say pulley but not sure why it would "growl". Belts look good, tight, straight?
  3. Jun 2, 2023 at 7:43 AM
    VBdiver58
    Virginia
    16" Toyota rims
    checked all that .
    it's more of a centrifugal motion like it is starving for fluid
  4. Jun 2, 2023 at 8:19 AM
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    Screen might be clogged in the res. You have to remove the res to clean it.
    Wulf and leid like this.
