Power steering hardline leak
Discussion in '2nd Gen. Tacomas (2005-2015)' started by k24jose, Nov 8, 2014.
  1. Nov 8, 2014 at 2:13 PM
    k24jose
    k24jose [OP] Member
    Prerunner SR5
    Hey taco world, today while my dad was changing his oil he noticed a leak. After I cleaned it up and looked again found it it's from the power steering line. Anyone have a quick fix, or is it possible to just swap lines with a new one?
    My fathers truck is a 07 with 198,xxx btw. Thanks.
    Attached is the leak from the fitting of the hardline
  2. Nov 8, 2014 at 2:52 PM
    tacoma4
    tacoma4 Well-Known Member
    I would try to tighten that nut a little before you replace the line, could have just backed off a bit.
  3. Nov 8, 2014 at 4:09 PM
    k24jose
    k24jose [OP] Member
    Prerunner SR5
    Tried tightening it already, wouldn't budge
  4. Nov 8, 2014 at 8:17 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    You should be able to swap it with a replacement. Make sure that you bleed the system before taking it out on the road after.
    Add fluid and turn the steering from side to side and top off fluid. Repeat until the level doesn't drop.
  5. Nov 8, 2014 at 8:31 PM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Well, you could try loosening it and slightly rotate the steel pipe, then re tighten. reseating my help. You may want to have the replacement part in hand before you start, just in case.
  6. Nov 8, 2014 at 9:17 PM
    k24jose
    k24jose [OP] Member
    Prerunner SR5
    Ok cool, so it is possible just to buy a replacement line from Toyota? Thanks for the tip on bleeding the system, never done power steering before.
    Will also give this a shot, but will first look into a replacement just in case I happen to mess up the line.
  7. Nov 8, 2014 at 9:35 PM
    el tardo
    el tardo Well-Known Member
    i normally dont say this,but a redneck fix is JB weld
    i would replace the line.
  8. Nov 8, 2014 at 11:55 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    No. Just No.
  9. Nov 9, 2014 at 7:52 AM
    k24jose
    k24jose [OP] Member
    Prerunner SR5
    Yea that's not gonna happen lol
  10. Nov 10, 2014 at 5:54 PM
    k24jose
    k24jose [OP] Member
    Prerunner SR5
    Does anyone know the part number for the hardline?
  11. Nov 10, 2014 at 8:25 PM
    tacoma4
  12. Nov 10, 2014 at 9:34 PM
    romafern
    romafern Hug diz nuts
    Rob
    80918 Let's meet!
    Paid for and saving a shit ton of $$$$$
    Thinking of adding a second battery...
    OP, when you replace it, do a write up.
  13. Nov 11, 2014 at 5:52 AM
    Canufixit
    New England
  14. Nov 11, 2014 at 5:59 AM
    Canufixit
    New England
    Also, from the Diagram, It looks like the tube can be easily removed?? If so remove and re install and check the flared ends on the tube. Perhaps your got something under the tuck that pushed/moved the tube and the strain on the connectors is causing the leak? You might be able to replace the pipe and use a flaring tool to flare the new tube ends??
  15. Nov 11, 2014 at 6:33 AM
    gearcruncher
    Canadain bumper technician
    Once the original fittings and hoses fail , I always went to a hydraulic shop and had a new set of hoses and connections made up .Hydraulic hose rated for 3500 PSI along with a better crimping design . Far better than anything available from the factory and most of the time , less pricey
  16. Nov 11, 2014 at 7:11 AM
    Canufixit
    New England
    From the OP pic and the parts breakdown link - it looks like flared tubing and not a hose??
  17. Nov 11, 2014 at 6:25 PM
    k24jose
    k24jose [OP] Member
    Prerunner SR5
    Correct, it is hardline (flared tubing) not hose. I was actually thinking of buying some stainless steel tubing, a bender and a flare tool and just making my own on a Saturday. Seeing as the bender tool/flare tool cost a pretty penny, rather find the part cheaper.
    I'm still planning on removing and resetting it but don't wanna risk messing it up and not being able to find a back up just in case.
  18. Nov 11, 2014 at 6:50 PM
    Canufixit
    New England
    good luck - and check to see if you can rent a flare tubing tool for a couple hours ??
  19. Nov 13, 2014 at 11:11 AM
    Bengland25
    Bengland25 Never Forget! 343
    Bradley
    Southern California
    09 Tacoma TRD
    MB Chaos 6 17" wheels, BF Goodrich All-Terrain TA/KO LT265-70R17, Anytime Fog Lights, Anytime Backup Camera, Bed Lights, Tailgate Lock, Light bar with 3 Hella 700FF's, Realtree Camo arm-rests, Anytime DTRL (With Switch), Blue Seas Fuse Block and Circuit Breaker, Custom Bed Light-Bar, Cobra 29 LTD Chrome, 4' Firestik, Masterlock Hitch Key Safe, Bed Storage Compartment Locks, Custom Shovel Bracket Mount, Flag Pole Mount (RED SOLO CUP FLAG!), DIY Washable Cabin Filter, URD MAF Cal., Homelink Garage Door Opener, Volant CAI w/ Ram Scoop, AeroTurbine 3030XL, URD Short Throw Shifter, Custom Satoshi, Blitzpro 21S, 2 Blitzpro 6LZ's, Blitzpro 6D, BAMF Sliders
    Just had the same crap happen to my truck, noticed the small leak yesterday on the driveway and then looked under the hood and truck this morning and the fluid is low and leaking out of the same spot. Did you have any luck finding a replacement part? I need to fix mine today as it is my only day off and I don't have another vehicle...
  20. Nov 14, 2014 at 7:45 AM
    k24jose
    k24jose [OP] Member
    Prerunner SR5
    I haven't found it as a separate part. Gonna look at a local junker or make my own line. Still gonna loosen and wiggle it around first to see if moved over time.
