Power steering is out.
Discussion in 'Technical Chat' started by kauairq, Mar 28, 2015.
  1. Mar 28, 2015 at 4:02 AM
    kauairq
    kauairq [OP] Member
    Kauai hawaii
    99 Tacoma 4x4
    I changed the pump, rack and pinion, pressure line, cleaned out return line. And still the reservoir over flows. As well still no power. Help
  2. Mar 29, 2015 at 2:45 AM
    kauairq
    kauairq [OP] Member
    Kauai hawaii
    99 Tacoma 4x4
    I jacked the truck up and turned the wheel left to right all the way about 20 times. (with the cap off) some air came out. Then started the truck up and the pump was screaming at first, I turned the wheel end to end a few times and the pump got quiet. However the reservoir still was overflowing as I was turning the wheel. It would bounce up and down as I turn the wheel. I dropped the truck and still no power. I even replaced the new pump thinking that the was defective. I'm lost!!
  3. Mar 29, 2015 at 3:07 AM
    kauairq
    kauairq [OP] Member
    Kauai hawaii
    99 Tacoma 4x4
    I also cleaned out the return line and removed the screen in the reservoir
  4. Mar 29, 2015 at 8:18 AM
    Blacktaco2042
    Blacktaco2042 Well-Known Member
    wisconsin
    supercharger/trd cat back 3inch lift 265/75/16 duratracs bumper guard led bar
    you plug in the connector on the pump to up the pressure when needed?
  5. Apr 2, 2015 at 7:03 AM
    kauairq
    kauairq [OP] Member
    Kauai hawaii
    99 Tacoma 4x4
    everything is connected to the pump that needs to be. Am I missing something? Cause it all looks like it was before I took the original pump out. I've broken it down to a faulty pump. I installed two rebuilt pumps and still the same results. I'm going to try a third pump and see if it works. Thats all I have left.
  6. Apr 2, 2015 at 9:56 AM
    armyoffoo
    armyoffoo Scrotie McBoogerballs
    Houston, TX
    2018 Tundra CM TRD Sport
    Is the ground wire connected to the back of the pump?
