power steering issues
Discussion in '4 Cylinder' started by 2.7, Jan 2, 2013.
  1. Jan 2, 2013 at 10:43 AM
    2.7 [OP] New Member
    Adam
    Fort Lauderdale Florida
    2.7 liter 4x 4 Tacoma
    new steering pump & new rack still no power steering I've been bleeding like my Haynes manual said but still no power steering?
  2. Jan 4, 2013 at 5:50 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    What the Hell? Anybody? [​IMG]
  3. Jan 4, 2013 at 5:53 PM
    blake5995
    blake5995 Well-Known Member
    Blake
    Truckee, CA
    98 Tacoma SR5 4x4 2.7L
    That pic is fucked up...
  4. Jan 4, 2013 at 10:50 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Blocked or kinked hose?
    Air pocket?
  5. Jan 5, 2013 at 10:22 AM
    Ga tacoguy
    Ga tacoguy Well-Known Member
    Rudy
    Augusta Ga.
    Extended cab Base model 4 cyl
    Tailgate mod, horn mod,storage door mod
    :) Adam, you may try this to see if the fluid is reaching the rack. The small hose is the high pressure line from the pump, you may try to loosen the high pressure line connector at the pump and see if it leaks fluid.
    If there is fluid, I would raise the front wheels off the ground, and turn the steering wheel from lock to lock and see if the air will bleed out of the system. Good Luck
  6. Jan 5, 2013 at 10:25 AM
    Cbass38
    Cbass38 Well-Known Member
    sebastian
    scottsdale
    07 pre runner
    projector hids,wheels,small lift,flowmaster
    sometimes the inner plastic sleeve seperates from the p/s line and goes into the rack stopping fulid flow. but generally it makes a loud whining noise
  7. Jan 5, 2013 at 10:30 AM
    98tacoma27
    Ben
    Not Beech Creek
    I think there is a screen in there somewhere that gets clogged.
