Power Steering Issues
Discussion in 'Technical Chat' started by PrezidentRedz, Oct 2, 2009.
  1. Oct 2, 2009 at 9:14 AM
    PrezidentRedz
    PrezidentRedz [OP] Uncivilized Creations Prez
    Redz
    Owings, MD
    00 Taco 4x4 Xtra Cab, Locked and Lifted.
    Custom Everything! WHAT º¿º
    hey guys im on Pump #4 in 2yrs. I just changed the pump again, bleed it good with all new fluid, but its still acting up. When I start the truck in the morning I can barely turn the wheel with out it squealing, and from what I have seen the squealing is from the Pump, the pulley stops turning. Like the pump locks up. also does this @ Full lock when its warmed up.
    Any idea on what could be the problem, and does anyone offer an after market pump for the 2.7L
  2. Oct 2, 2009 at 9:40 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Define "bled the pump"
  3. Oct 2, 2009 at 9:41 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Loose belt or water in the fluid.....
  4. Oct 2, 2009 at 11:11 AM
    PrezidentRedz
    Redz
    Owings, MD
    Installed new pump, took return hose off, poured new fluid in pushed old shit out.
    Belts not loose and went through 2qts flushing the system.
    The pump stops spinning when trying to turn.
  5. Oct 2, 2009 at 11:13 AM
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    Muffler bearing?
    Sorry redz. Hope you figure out whats wrong!
  6. Oct 2, 2009 at 11:15 AM
    PrezidentRedz
    Redz
    Owings, MD
    yeah man me to, this is really starting to piss me off. I might go take that Rack off of the 98 in my Barn.
  7. Oct 2, 2009 at 12:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The bolts are not over torqued are they ??
  8. Oct 2, 2009 at 12:44 PM
    PrezidentRedz
    Redz
    Owings, MD
    Bolts? which bolts are you referring too?
  9. Oct 2, 2009 at 12:51 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    I think you need to inspect the rack. You may have metal in your system from the previos pump failures.
  10. Oct 2, 2009 at 2:05 PM
    PrezidentRedz
    Redz
    Owings, MD
    thats what im thinking. Uhh this frakking sux!
  11. Oct 2, 2009 at 3:53 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Redz, you should able to disassemble the pump and inspect it.
  12. Oct 3, 2009 at 5:09 AM
    PrezidentRedz
    Redz
    Owings, MD
    Im taking a pump and Rack off of the 98 in my Barn. hey 98, what should I inspect?
