Power steering issues
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Silentb, Dec 30, 2018.
  1. Dec 30, 2018 at 5:15 PM
    Jon G
    Jon G Hoarding Tacomas one at a time,
    Jon
    St John's Newfoundland Canada
    02, 04 & 07 Tacoma
    Magnaflow 2.5 Catback Exhaust K&N filter
    Link is in my signature
    Also shameless plug for my 007 Taco Pro build
  2. Dec 30, 2018 at 8:59 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Did you find a bad joint?
    Jeffch likes this.
  3. Dec 31, 2018 at 4:12 AM
    Jon G
    Jon
    02, 04 & 07 Tacoma
    :rasta:
    Jeffch and b_r_o[QUOTED] like this.
  4. Dec 31, 2018 at 6:26 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    He said a bad joint. Not a good joint. LOL
    Jeffch, Jon G[QUOTED] and b_r_o like this.
  5. Dec 31, 2018 at 11:58 AM
    Silentb
    Silentb [OP] Member
    Brandon
    11 tacoma acess cab
    Nothing YET!!!
    I looked I didnt see or feel anything outta the ordinary
    Jeffch likes this.
  6. Dec 31, 2018 at 11:59 AM
    Silentb
    Silentb [OP] Member
    Brandon
    11 tacoma acess cab
    Nothing YET!!!
    Is there really such thing as a bad joint :D
    Jeffch and Jon G like this.
  7. Dec 31, 2018 at 12:52 PM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    I can’t roll for chit so yea mine!
    But cool it looks good!
    Kinda sucks cause you gotta hunt still, I will keep mine clean and greased so it isn’t a issue later.
    I did the whole is it leaking, flushed the fluid cleaned the screen.
    Then found threads about the lower shaft!
    Pretty much found answers to maintaining my taco here.
    I enjoy doing it myself but don’t like not knowing what I’m getting into.
    Good luck and happy new year.
  8. Feb 21, 2019 at 10:18 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Ugh power steering issues suck.
    When I first got this truck it had a torn boot on the pax side inner tie rod. Replaced both sides tie rods. Couple months later lost hydro assist, noticed both new boots are full of fluid so probably rack end seals are leaking.
    Fluid is dirty black too.
    No power steering at a stand still but if I throw her in neutral and rev I get some hydro assist back but the pump whines when I turn the wheel.
  9. May 14, 2022 at 12:15 PM
    TacoTuesday1
    SD CA
    Steering started feeling weak recently
    doesn’t return to center
    have a feeling it might need a rack, pump, and column rebuild
    I’ll start by lubing the column shaft u joints
    I just opened the outer tie rod clamps to stick a pick tool into the boot to try and pry it open a bit to see if any fluid leaks out. And some did on the passenger side. It was black even though I keep my fluid in good shape with Mobil 1 atf
    curious to know if anyone else has gone through this
    Seems like a good opportunity to swap in a strong tundra rack
    But finding one, rebuilding it, and making it fit looks like a pain and expensive
