power steering leak
Discussion in '1st Gen. Tacomas (1995-2004)' started by VintageFast, May 13, 2016.
  1. May 13, 2016 at 5:42 PM
    VintageFast
    VintageFast [OP] Well-Known Member
    Jim
    DFW, Texas
    02 Prerunner 3.4
    20160513_192836.jpg 20160513_192836.jpgOk folks. I've got a leak. It's not the lines. It's the part that the steering stem bolts into the rack. I'll try and post pics.
  2. May 13, 2016 at 5:45 PM
    VintageFast
    Jim
    DFW, Texas
    02 Prerunner 3.4
    The leak is in the silver part that the aluminum lines go into.
  3. May 13, 2016 at 6:08 PM
    VintageFast
    Jim
    DFW, Texas
    02 Prerunner 3.4
    Sorry... I don't know how to do this. Anyway. ... does anyone know of a rebuild kit or the part number for the entire aluminum part?
  4. May 13, 2016 at 6:10 PM
    VintageFast
    Jim
    DFW, Texas
    02 Prerunner 3.4
    Again... I apologize. The aluminum part that bolts to the top of the rack that the line bolt to
  5. May 13, 2016 at 9:01 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    You need a seal from the dealer, but the problem is you also need a special tool to get it out. I had to make one and it wasn't easy.
  6. May 14, 2016 at 11:06 AM
    VintageFast
    Jim
    DFW, Texas
    02 Prerunner 3.4
    Can I just buy the part the steering shaft slips into?
  7. May 14, 2016 at 1:33 PM
    Dustrider
    Dustrider Well-Known Member
    Dave
    Hillsboro Oregon
    98 Tacoma 4x4 2.7
    Sorry but its hard for me to tell what you are asking about. I can see no major oil leaking in the picture Is it leaking drops out of the steering shaft seal on the driveway ? or are you talking about that teeny drizzle around where the aluminum cases bolt ?
    I could definitly get to sleep at night not worrying about that
    If its pouring out then you might want to fix it.
  8. May 14, 2016 at 4:52 PM
    VintageFast
    Jim
    DFW, Texas
    02 Prerunner 3.4
    It was leaking. About a puddle the size of a personal pizza. It's not leaking now. .. not sure why. I put ATF Dextrose in it and it stopped. For anyone having the same problem. .. here's the part number for the seal kit... 04455-35130. This is the kit to rebuild the valve assembly. It's $76 from the dealer.
  9. May 14, 2016 at 5:02 PM
    VintageFast
    Jim
    DFW, Texas
    02 Prerunner 3.4
  10. May 16, 2016 at 9:58 PM
    Pabloeeto
    Pabloeeto Well-Known Member
    Paul
    San Diego
    06 DCSB TRD Sport 4x4
    K&N filter, 3.5 Aux input mod, Fox 2.0 Coilovers, Fox 2.0 Resi Shocks, Element UCAs, Old Man Emu Dakar Leaf pack.
    Put some Lucas power steering leak fix in it. Worked well for my 4Runner
