Power Steering Leak
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wberrier14, Aug 18, 2021.
  1. Aug 18, 2021 at 8:06 PM
    wberrier14
    wberrier14 [OP] Member
    Hey Guys,
    Was doing some off roading with my Tacoma and had a couple hard bounces. When I restarted the car an hour later I could feel resistance and a “squeaking” noise when I tried to turn the wheel sharply. First thing that came to mind was power steering fluid, then saw it leaking quite a bit when I lifted hood and checked under truck. Is there any quick fix for this like just replacing fluid or do I have to go to the shop for this? Any advice would be great, not trying to spend a couple $100 for nothing. Thanks!
  2. Aug 18, 2021 at 8:30 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Adding fluid won’t fix the leak.
    But yes, add fluid.
    Then figure out where it’s leaking.
    No way to tell how easy or hard it will be with knowing where the leak is.
    If it’s the rack, good luck. It can be difficult. But it’s doable in a driveway.
  3. Aug 18, 2021 at 8:30 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Put a little in it and see where it's leaking from.
    TnShooter likes this.
