Power steering leak
Discussion in '1st Gen. Tacomas (1995-2004)' started by 45acp, Feb 25, 2010.
  1. Feb 25, 2010 at 7:43 PM
    45acp
    45acp [OP] Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    I think I've got a power steering fluid leak. A few weeks ago I heard a loud groaning noise when I would turn the wheel. I filled the ps fluid and it was quiet again. About 12 days later it was groaning again, and now I've been filling it every 8-12 days.
    I haven't seen any dripping/puddles (leaking too slow I guess) and I'm not sure what areas or parts to be checking. Any advice?
  2. Feb 25, 2010 at 7:50 PM
    HondaGM
    HondaGM CallSign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    check the power steering rack at the boots, and the pump.
  3. Feb 26, 2010 at 3:21 PM
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Well crap. I guess it's obvious now that I have a leak. It's hard to tell the exact location but it looks like it's coming from the boot? Up close it looks like it's cracking. As I've stated in the past, I'm kinda retarded when it comes to vehicle maintenance. Is this something I could do myself, or does it have to go to the mechanic?
    Thanks
  4. Feb 26, 2010 at 5:57 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    is there black paint all over the bottom of your truck?
  5. Feb 26, 2010 at 6:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The boot is just a Dust cover. You have a leak from the rack seal.
  6. Feb 26, 2010 at 7:17 PM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '04 Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Dorkel
    I had that. Replaced the whole rack...set me back 550 or so. It happened because the boot tore, which allowed dirt and mud to get in there and mess up the whole rack.
  7. Mar 3, 2010 at 3:02 PM
    cordillera
    cordillera New Member
    Santa Fe
    03 SR5
  8. Mar 3, 2010 at 3:20 PM
    Zac
    Zac Member
    Zac
    tucson
    00 Tacoma SR5 4X4
    3-4 inch lift
  9. Mar 3, 2010 at 4:24 PM
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    I took a closer look the other day and apparently the return hose that connected to the steering rack was cracked and leaking pretty bad. $2.75 for a new hose. yay!:D
    TacoBunny likes this.
  10. Mar 3, 2010 at 4:31 PM
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    I have no idea what that stuff is...
  11. Mar 3, 2010 at 8:47 PM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    my taco has power steering?
    mines a real bitch when it warms up but first thing in the morning its great
    i need to get around to fixin that :(
  12. Mar 3, 2010 at 8:54 PM
    Dane-Taco
    Dane-Taco Well-Known Member
    Justus
    Wasilla, AK
    '10 Doublecab 4x4 TRD Off-Road
    Bilstein 5100s set at 0, OME 886 coils, Camburg Ball-Joint UCAs, 295/70/17 Nitto Trail Grapplers on 17x9 Moto Metal 957s, 2" Tuff Country AALs, SX8000 Gas Shocks (Rear), Homemade Satoshi Grill, Redline Hood Struts, Locker Anytime Mod, Map Light Mod, Diff Breather Mod, Fog Lights Anytime Mod, Extra Bed D-Rings, Sock's Badges and Decals, PIAA 520's, Illuminated 4x4 Switch Mod
    Had the same issue on my '99. I was able to get a refurb for about $300.
  13. Mar 4, 2010 at 2:28 PM
    kevhogaz
    kevhogaz Low Speed, High Drag
    Queen Creek, Arizona
    SR5 PreRunner
    3" lift front & rear, Air Raid Intake System
    $900.00 to replace the steering rack? Man, I'm in the wrong business!! :D
  14. Nov 21, 2017 at 5:24 AM
    Fiesta346
    Fiesta346 Well-Known Member
    PA
    2013 Tundra rock warrior
    Having the same issue..hoping to pin point the leak and replace a line or 2 how can you confirm it's the actual rack that is shot
  15. Jan 4, 2023 at 8:30 AM
    TacoBunny
    TacoBunny Well-Known Member
    AZ
    1997 5 Lug 5VZ
    would you happen to remember which hose you replaced?
