Power Steering Leak ?
Discussion in '1st Gen. Tacomas (1995-2004)' started by gravel, May 27, 2010.
  1. May 27, 2010 at 9:34 PM
    gravel
    gravel [OP] Member
    I picked up a 2000 prerunner a few months ago and have started fix it up.
    I noticed a slow leak from near the front drivers side. It is right above the cv boot on the drivers side. It looks like a seal has failed. From what I can tell it is directly below where the intermediate shaft assembly joins the rest of the steering. I have attached a image that shows the area I am talking about.
    Does anyone know if it is possible to replace just this seal and if so where to get it from?
    Thanks
  2. May 27, 2010 at 10:12 PM
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
    thats exactly where mine leaks from, to tell you the truth it doesnt leak very fast i just check it every other week or so, but that part can be fixed for reasonable price
  3. May 28, 2010 at 6:21 AM
    shift96
    shift96 Well-Known Member
    Pretty common for that to be a little wet.
