Power Steering leaking
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Millerman93, Feb 10, 2017.
  1. Feb 28, 2017 at 1:48 PM
    CheapLaborTJ
    CheapLaborTJ Well-Known Member
    Maybe just a "coincidence" that since Toyota moved Tacoma production to Baja and Texas quality and reliability issues have become more prevalent.
    From what I understand most of the Double cabs are made in Baja and the Access cab is only made in Texas.
    Could be quality control with outsourcing so many parts from all over the world.Chinese steel and copper is some of the worst .
  2. Jan 27, 2020 at 7:46 AM
    Jthizz2006
    Jthizz2006 Well-Known Member
    Jesse
    16 black tacoma DCSB SR5 4x2
    was that covered under warranty
  3. Feb 4, 2020 at 5:41 PM
    HME1987
    HME1987 New Member
    2017 Magnetic Grey DCSB OR
    Any updates on this ? Just went to purchase a 2017 TRD sport 51k miles. Noticed a fluid leak off the skid plate. Previous owner also had a marker line on the power steering reservoir as if to monitor fluid loss... Might go back to looking at 2nd gens
  4. Feb 5, 2020 at 4:59 AM
    TBLTravy
    TBLTravy Well-Known Member
    2019 SR5 4X4 Sement , 2016 DCSB *sold*
    Timing chain cover. Most likely. Oil leaks right where you are mentioning.
    Skydvrr likes this.
  5. Feb 5, 2020 at 10:26 AM
    shackley
    shackley Well-Known Member
    Albuquerque, New Mexico
    2018 TRD Pro MT Super White
    RCI rock sliders, Goodyear Ultraterrains 265/70/R16, BAK X2 tonneau
    Mine did on my 2013, no problems on the 2018 yet.
  6. Feb 5, 2020 at 10:50 AM
    AKGSD
    AKGSD Warranty denied
    Joe
    Alaska
    2019 QSDCSBTRDOR4X4V6MT
    Dog hair, metaltech 4x4 rocksliders, KBVooDoo bed risers, Smittybilt RTT, 3” spacer lift (Removed!), caliraised ditch lights, amazon rock lights, OVtune, Skewp
    Can’t really agree with that - My Taco was built in Texas and is a mess. And i’ve had some mexican built Fords with minimal issues
    Realistically, aren’t the best tacos made in Mexico?
    zoo truck likes this.
  7. Feb 5, 2020 at 2:23 PM
    Jthizz2006
    Jesse
    Is that on the passenger side? If so, I may be having that same leak. But it only does that every other 3rd day
  8. Feb 11, 2020 at 3:53 PM
    Andreas2
    Andreas2 New Member
    Andrew
    Tacoma sr5
    2 inch lift, running board, fuel rims
    yeah, having the same issue with my 2016, the leak is very small, I noticed it while changing my oil filter. In fact it's so small doesn't even really drip. But I do see that it is the front top passenger side. I have 47 miles is this a warranty covered problem.
  9. Apr 27, 2020 at 1:11 PM
    ToyotaMo
    ToyotaMo Member
    2017 Tacoma Off Road
    I recently went in to the dealership to get my oil changed on my 3rd gen and they informed me how my power steering is leaking. They said it would be over $1,700.00 to fix! My truck is no longer under warranty. Any recommendations?
  10. May 16, 2020 at 10:46 PM
    jsanford
    jsanford Member
    The PNW
    2011 Tacoma Wonderbread White
    Variable-speed Interval Wipers
    Ha! Same thing with mine today. We’re going to service it ourselves; it’s a 2WD so shouldn't be too bad.
  11. May 17, 2020 at 5:51 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Hopefully its not a steering rack issue like they had on the gen1 tundras. Had to replace mine after a few years...the salt caused the rack to corrode eating holes though it.
  12. Jun 13, 2020 at 3:18 PM
    Tacoma18d
    Tacoma18d Member
    V
    2016 Tacoma DCSB TRD Off Road
    Anyone know if this or the timing cover leak are covered under the powertrain warranty? Got under my truck to change the diff fluids and noticed a leak on the passenger side. Looks like engine oil but the power steering pump is dripping. Doesn't smell like ATF.
  13. Aug 19, 2020 at 7:45 AM
    shermanator223
    shermanator223 New Member
    2017 silkver tacoma trd sport
    lift kit, wheels and tires
    Well it looks like I've been hti with the same issue. Took my truck for its 50k service and they said i needed a new steering rack because there was fluid leaking. I brought it home and looked and turns out my pump is covered in oil and dirt. My resevoir didnt seem to be low so I'm guessing it could be engine oil. Been having a good amount of problems wih this truck lately, definitely not what I expected from Toyota.
    AKGSD likes this.
  14. Apr 8, 2021 at 6:02 PM
    AZ_Taco16
    AZ_Taco16 Member
    Any updates on this? Have the same leak that’s consolidating on the power steering pump. It’s getting worst and today I noticed it dripped for the first time. Curious to see what others have found and if it’s covered under warranty.
  15. Aug 3, 2021 at 3:39 PM
    #35
    nate16yota
    nate16yota Member
    Nathan
    2016 Inferno TRD Sport
    I’ve noticed on my truck there’s a leak coving from right above the skid plate. It looks like the hose coming from the Power Steering reservoir above. What would cause the pipes to be stretched and braking?
