Power Steering mystery - now a drive shaft mystery...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mgord, Nov 3, 2020.
  1. Nov 6, 2020 at 2:44 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    actually no.............far from it
    no pressure i rack to effect centering
    acts like a grocery cart wheels want to self steer ................go willy nilly
    if U were to take out the rackthen flat tow the front wheels would not track straight
  2. Nov 6, 2020 at 6:44 PM
    mgord
    mgord [OP] Well-Known Member
    Harrisburg, PA
    07 TRD
    K&N, Leaf Springs, Home Built Camper
    Update - the vibration came from the shop I had it at put the drive shaft 180 degrees from correct. Cost me $180. Had to fight the original shop for my $180 back. Seems my nail polish from 1/ 1/2 years ago was correct. If they had set it back to my nail polish all would be good.
    How is is that me as back yard mechanic was better than a "professional". Very frustrating....
  3. Nov 6, 2020 at 6:49 PM
    ICECOLDBEER
    ICECOLDBEER Well-Known Member
    2006 Tacoma 2.7L SR5
    Simple enough fix at least! Morons.
  4. Nov 6, 2020 at 7:04 PM
    Muddinfun
    Muddinfun Well-Known Member
    Now do you believe us that your steering issue is the intermediate shaft and not the pump like those morons told you?
    Chris(NJ) likes this.
  5. Nov 7, 2020 at 4:39 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    The older I get the more I realize there's hardly any professionals holding professional occupations.
  6. Nov 7, 2020 at 4:52 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    After seeing this picture I can tell you your intermediate steering joint is the culprit. There's corrosion in there making it bind. I had the same issue on my 2009 when I bought it last year. There was a weird hard dead spot, which is not ideal for the windy, twisty back roads I drive on. I sprayed some penetrant on it and worked the steering for a little bit. Afterwards I coated it with Fluid Film and has been fine ever since. I try and re-coat it every 6 months or so, usually lines up with my oil change. Although my truck isn't as rusty so yours will more than likely need replacement.
  7. Nov 7, 2020 at 6:34 AM
    ROAD DOG
    FEW
    driveshaft 180 out would not explain or eliminate the ‘ dead ‘ zone U described orig post
    it would substaniate the vibrations
  8. Nov 8, 2020 at 7:16 AM
    mgord
    Harrisburg, PA
    07 TRD
    2 different issues. Vibrations taken care of - although I got ripped on that one.
    Working on the dead zones. Going out for axle grease to slap on the shaft. Going to replace it when I get home. Just trying to figure out of the pump is getting replaced as well.
  9. Nov 8, 2020 at 7:39 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    If you're looking for a quick / temporary fix for the steering shaft, use penetrating oil. Grease won't get into the joint.
    SocalTaco15 and Muddinfun like this.
  10. Nov 8, 2020 at 2:31 PM
    mgord
    Harrisburg, PA
    07 TRD
    Plan is to spray the bejeebers out of it with WD-40 then lube it up with some axle grease. Maybe the grease will ooze into the joints.
  11. Nov 8, 2020 at 2:52 PM
    Too Stroked
    Tom
    Sounds like a plan. Tell us how it works.
    If it is the intermediate shaft and you replace it, I'd recommend coating the new one with Fluid Film to protect it. That's what I did with mine.
  12. Nov 18, 2020 at 5:33 AM
    mgord
    Harrisburg, PA
    07 TRD
    It's been about a week now. We are in NC now.
    I sprayed the joint with WD-40 and that seemed to help a bit. Then I lubed it up properly with axle grease and that made everything better. No dead spots at all. Will still replace the intermediate joint but will do that when I get back.
    Too Stroked likes this.
  13. Nov 19, 2020 at 1:47 PM
    mgord
    Harrisburg, PA
    07 TRD
    So I go looking to buy an intermediate shaft and there seems to be a big discrepancy in the price. For example on Amazon I can get a unknown name (to me) for $60:
    https://www.amazon.com/Intermediate...=1&keywords=45203-04021&qid=1605822179&sr=8-2
    or an OEM part for $200:
    https://www.amazon.com/TOYOTA-Toyot...1&keywords=45203-04021&qid=1605822356&sr=8-19
    RockAuto doesn't seem to stock this piece and the $60 versions are sold by brands I don't recognize.
    You guys have any preferences or should I suck it up and buy OEM?
  14. Nov 19, 2020 at 2:36 PM
    Too Stroked
    Tom
    I used to drive the Wholesale Parts Delivery truck at the Toyota dealership I work at. I got to visit lots of shops and talk to lots of people who knew their stuff. Once (at a shop I trust) they ordered an OEM steering shaft - which I delivered. I found out when I got there that the reason they ordered it was to compare it to the no name steering shaft they got from a local parts store. I got to see the parts side by side. The aftermarket shaft was a total joke. It looked like a 3/4 scale version of the real thing. Oh, and it didn't fit for crap. Needless to say they took the Toyota part. Any questions?
  15. Nov 24, 2020 at 12:39 PM
    #35
    mgord
    Harrisburg, PA
    07 TRD
    Back home in PA and the inspection was up so ran it through (we have yearly emissions and mechanical). Told them to take a look at the intermediate shaft and they noticed no issues. They're thinking power steering pump.
    For now going to do nothing until the steering issue comes back.
  16. Nov 24, 2020 at 12:59 PM
    #36
    gearcruncher
    Canadain bumper technician
