Power Steering Noise
Discussion in '1st Gen. Tacomas (1995-2004)' started by Fredfifty, Dec 21, 2020.
  1. Dec 21, 2020 at 1:28 PM
    Fredfifty
    Fredfifty [OP] Back in a Mini
    Dave
    Big Island - SF Bay Area
    99 5 Lug V6
    DJM 3/4 DJM UCA BJ FLIP CALMAX SHOCKS POLYURETHANE SWAY BAR BUSHINGS POLYURETHANE UCA BUMPSTOPS ROLLED FENDERS DJM 4 INCH ANGLED BLOCKS (STEEL) MINI C-NOTCH FROM ROHDE FABRICATIONS MJBTACO LOWPRO BUMPSTOPS CALMAX SHOCKS ROLLED FENDERS
    can anyone explain the terrible screeching sound that's heard when i turn the steering wheel lock to lock...does the rack need attention or is it the pump? there is fluid in in the pump btw.
  2. Dec 21, 2020 at 2:03 PM
    rackomint
    rackomint Well-Known Member
    Anna TX
    2001 5-spd SR5 3.7L V6 4WD
    I'd try a full flush before anything and make sure you fill with toyota ATF and NOT power steering fluid
    Fredfifty[OP] likes this.
  3. Dec 21, 2020 at 2:06 PM
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 185k
    881/5100/Dakars 4R wheels / TBU / New frame
    There is also a screen in the bottom of the power steering reservoir. If it's clogged then the pump will be starved of fluid and may be causing the noise. Here's what mine looked like after being cleaned:
    rackomint likes this.
  4. Dec 21, 2020 at 2:08 PM
    Fredfifty
    Dave
    99 5 Lug V6
    thats after all the fluid was flushed or did you use the turkey baster method (which is what i just read about). i will definitely check that screen
  5. Dec 21, 2020 at 2:10 PM
    CrustyTaco
    Todd
    Louisville, KY
    I was replacing my P/S lines, so I drained the entire system to start. You can separate the reservoir from the pump and clean the screen without having to remove the pump. If the screen is dirty you can turn the reservoir upside down and spray some brake cleaner to clear it.
    Fredfifty[QUOTED][OP] likes this.
  6. Dec 21, 2020 at 2:14 PM
    CrustyTaco
    Todd
    Louisville, KY
  7. Dec 21, 2020 at 2:15 PM
    Fredfifty
    Dave
    99 5 Lug V6
    CrustyTaco[QUOTED] likes this.
  8. Dec 23, 2020 at 8:45 AM
    skeezix
    skeezix Ol' Geezer
    Colorado
    1998 Limited
    If you hear the screech only when the wheels have reached their limit of travel, try tightening the belt (or replacing it!) that wraps around the PS pulley before taking anything apart.
  9. Dec 23, 2020 at 9:37 AM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    check your fluid and see it its really dark, and if it smells burnt. And then do all of the above, and don't forget it uses ATF fluid not power steering fluid. I'm just waiting on getting over a nasty sinus infection and a bit warmer day, and then I'm going to do the Timmy the Tool Man drain, check the screen, and flush mine out with new fluid since mine has turned dark and need to be replaced.
