Power Steering Pressure Hoses?
Discussion in '1st Gen. Tacomas (1995-2004)' started by vettehigh, Nov 6, 2020.
  1. Nov 6, 2020 at 9:18 AM
    vettehigh
    vettehigh [OP] Tacoma Tank
    Jon
    Upstate, NY
    Need to change both of mine, but OEM 44410-04030 (includes both hoses) runs $400 or so.
    I can get Gates (365872) pressure hose and Gates (365871) return hose for $155 (total for pair)
    What should I do?
  2. Nov 6, 2020 at 9:21 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Take your old set down to a place that makes hydraulic hoses and ask them to duplicate what you have....
    Sogoku19 likes this.
  3. Nov 6, 2020 at 9:24 AM
    vettehigh
    Jon
    Upstate, NY
    Will not have the time, my tech is 40 minutes round trip for me
  4. Nov 6, 2020 at 9:30 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    I'd just get the gates ones. Hoses aren't exactly magical.
    JudoJohn likes this.
  5. Nov 6, 2020 at 9:40 AM
    vettehigh
    Jon
    Upstate, NY
    Will do. I will get the gaskets too. Is that all or do I need the power steering return line end fitting?
  6. Nov 6, 2020 at 9:44 AM
    0xDEADBEEF
    I think the return line fitting is just a hose clamp, but its been a few months since i last looked.
    vettehigh[OP] likes this.
  7. Nov 12, 2020 at 4:47 AM
    vettehigh
    Jon
    Upstate, NY
    I forgot to ask, what is the labor involved in changing both hoses?
    Thanks
  8. Nov 12, 2020 at 6:55 AM
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 185k
    881/5100/Dakars 4R wheels / TBU / New frame
    I replaced my lines this summer, and I used the Sunsong lines, which ran me about $90. It was not a fun job. Labor wise, I spent probably ~8 hours. But I dropped the rack and replaced the rack bushings, LBJs and outer tie rods. If you can keep the rack in place you could probably replace the lines in the 2-4 hour range. Check out this thread, post #11.
    https://www.tacomaworld.com/threads/removing-rack-and-pinion-issue.681590/#post-24070434
    Removing the rear connector at the rack is a giant pain in the butt, which is why I ended up dropping my rack, but if you can make ghack's technique work you should be able to keep the rack in place.
  9. Nov 12, 2020 at 7:33 AM
    vettehigh
    Jon
    Upstate, NY
    Thanks...My tech just finished and $141 labor charge
    CrustyTaco[QUOTED] likes this.
  10. Nov 12, 2020 at 7:48 AM
    Sogoku19
    Sogoku19 Well-Known Member
    03 Tacoma (black)
    This is the way. Went through the same thing thinking the prices were strangely high. Got mine rebuilt for $17.
