Power Steering Problem?? What's Wrong???
Discussion in 'Technical Chat' started by TacoYes, Oct 21, 2016.
  1. Mar 12, 2020 at 3:16 PM
    PGHquinn
    PGHquinn Member
    Rob
    McMurray, PA
    2011DBLcab
    LED bed light strips Smittybuilt step bars Avid offroad light bar Grillcraft mesh grill Fold a cover g4 bed cover Pro Comp 7063 Bilstein 5100's front @ 1.75" Bilstein 5100 rear Toytec progressive AAL
    An old post but I thought I’d add to it. Hit the U joint with PB Balster and all is good. Power steering fluid was low so I added. Still jerky in turning. PB blaster did the trick. I’m guessing I’ll have to hit it from time to time. Thanks for the info above fellas!
  2. Mar 13, 2020 at 2:35 AM
    Stormtrooper457
    Stormtrooper457 Well-Known Member
    Indiana
    2013 TRD Sport DCLB
    Nano Ceramic Tint Heated Clazzio Seats TRD Pro Wheels Softopper
    I had a power steering pump completely fail in a previous vehicle. I drove it around for 6 months like that before being convinced to replace it.
    When your vehicle is actively moving, you don't need power steering. You only need it when your vehicle is moving very very slowly (or not at all). I only noticed it when I was parking the vehicle.
    So even if your power steering pump was having problems, you wouldn't notice it when driving around. If you do it's likely to be issues with the steering itself.
    So just to give you piece of mind. It's not likely to be the pump.
    FishingInSand likes this.
  3. Mar 26, 2020 at 2:14 PM
    Ace115
    Ace115 Well-Known Member
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    Started having this problem myself recently. I am also getting a whine which i believe is the pump failing. is there a better option for the PS pump than OEM?
  4. Mar 26, 2020 at 2:31 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    The BBB OEM reman pumps are said to be good, according to the likes of South Main Auto and EricTheCarGuy. Avoid Cardone if you can.
    tacoma16 and Ace115[QUOTED] like this.
  5. Mar 26, 2020 at 2:48 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    So didn't mine I added maybe 3 oz of fluid it went away.
  6. Mar 26, 2020 at 7:31 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    dont know what or how U changed fluuds
    sometimes ......... even a good mechanic
    can get air in the lines
    no less the pump c o u l d be going bad
    if U need a pump
    change out a pump
    make sure 7 dont get air n the lines
  7. Apr 14, 2022 at 4:25 AM
    kool
    kool Member
    ny
    2013 Tacoma
    this did the trick for me, probably saved me time & money, thanks
    06Tacooo likes this.
  8. May 11, 2022 at 8:10 PM
    Clearwater Bill
    Billy
    Largo Florida
    The PB is a diagnostic tool here, not the fix.
