power steering problem
Discussion in 'Technical Chat' started by fitryders2, Mar 9, 2011.
  1. Mar 9, 2011 at 6:06 PM
    fitryders2
    fitryders2 [OP] Well-Known Member
    shawn
    virginia
    07 trd sport
    so my power steering is whining from the moment i start my truck until i turn it off. when i drive the whine gets louder with rpms. but if i turn the wheel at idle it doesnt increase whining. any ideas? power steering pumps are expensive and i just wanna see if anyone has any ideas before i buy a new pump to find out its something else. thanks
  2. Mar 9, 2011 at 6:10 PM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    04 Tacoma 4x4, V6, 5spd
    Squattin'
    Do you see any leaks?
  3. Mar 9, 2011 at 6:18 PM
    fitryders2
    shawn
    virginia
    07 trd sport
    fluid level is fine. fluids arent clear but are clean. and i need to get up under it. there is a leak but it looks like the driver side cv axle seal. but i know the steering rack fittings are right over top of that. so yes i do need to look closer at that. but im pretty positive its the axles seal
  4. Mar 9, 2011 at 6:24 PM
    Max-4_Yota
    Michael
    South Carolina
    Squattin'
    Check for leaks, mine went out a while back, one day it was fine, i crunk it up the next morning and it was whining like a baby, no fluid.
  5. Mar 9, 2011 at 6:26 PM
    fitryders2
    shawn
    virginia
    07 trd sport
    k i guess ill keep checking fluid level till the weekend and see if anything changes. hopefully friday ill get some free time to check real good for leaks.
  6. Mar 9, 2011 at 7:19 PM
    fitryders2
    shawn
    virginia
    07 trd sport
    Forgot to mention power steering still works fine.
