Power steering problems.
Discussion in '1st Gen. Tacomas (1995-2004)' started by TaCoTruckBQ, Nov 9, 2023.
  1. Nov 9, 2023 at 12:46 PM
    TaCoTruckBQ
    TaCoTruckBQ [OP] Member
    Brittney
    Toyota tacoma pre-runner 2001
    Hello,
    I have a 2001 Toyota Tacoma Pre-runner 2.7l . I have had so much trouble getting my power steering under control. It went out several years ago, but I let it get to the point that my rack and pinion also needed replacing. Fast forward, we've changed out the Rack and pinion, the power steering pump (which now the pulley tensioner bolt is broken due to boyfriend hitting it with a hammer), but all said and done and my power steering is still making noises. I'm guessing I have to change out the lines? the pump reservoir is still getting all gunked up, so i'm assuming that its all the junk left in the lines from before? has anyone had similar issues? Any advice. Thank you.
    Apologies if I sound like an idiot, I don't know a whole bunch about working on my truck other than the basic tune up stuff.
  2. Nov 9, 2023 at 12:58 PM
    TimPall13
    TimPall13 Well-Known Member
    Tim
    Sandy Oregon
    3link SAS 02 SR5 Limited V6
    Lift: TrailGear 3link SAS with Fox 2.0 Coil overs in front. Custom Alcan Leafs with relocated Fox 2.0 shocks in rear. Sitting at 6in of lift. Armor: Relentless Fab Front bumper with home made hoops and Warn VR Evo 10s winch. Relentless Fab Rear bumper with swingout gate. Gears/Grip: 4.88 gears with ARB Air lockers front and rear. 35x12.5 Mickey Thimpson Baja Boss MTs on 17in Trail Ready Beadlock wheels. Lighting: 6000k 55w HID head lights in Retrofit Prejectors, KC Slim Light LEDs behind a Grillcraft grill and on CBI windshield mounts, And LED rock Lights. Performance: 6" deckplate mod, URD Crank Pulley, K&N air filter, ISR mod, and a AirRaid throttle body spacer, magnaflow muffler. Audio: Alpine speakers and sub running on a Alpine 5ch amp. All ran with Stinger wire kit, and a Alpine touch screen reciever. Extras: 15% Window Tint, Spray in bed liner, LineX coated factoey fender flares, Custom Roof rack/Track system, SoftTopper Canopy, Viair Dual 444c Onboard air with dual 2.5Gal tanks.
    Hi Brittany, welcome to TW. What kind of noise are you hearing? Is it all the time or under specific conditions? Did you bleed the the air from your system when to changed the pump and rack?
  3. Nov 9, 2023 at 1:56 PM
    TaCoTruckBQ
    Brittney
    Hi Tim,
    Thank you for responding. The noise is a constant whine, especially when going under 10 mph while turning (so basically, at low speeds the noise is more prominent while turning). I did bleed the system after both installations, and we're talking like 20 minutes of it. The one thing that we have not changed are the lines, not since I inherited the truck from my father back in 2008.
  4. Nov 9, 2023 at 1:57 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    My guess is the screen in the pwr steering reservoir
    when I got my taco, my PS fluid was black as oil
    My screen took 2 cans of brake clean to be respectfully clean with flash light held from the bottom of the removed reservoir
    https://m.youtube.com/watch?v=fZPYnp_OmyE
    TaCoTruckBQ[OP] likes this.
  5. Nov 9, 2023 at 1:59 PM
    ControlCar
    Steven
    Sugar Land TX
    The pwr steering fluid is a detergent (dextron transmission fluid)
    Think your lines are fine!!!
  6. Nov 9, 2023 at 4:01 PM
    TaCoTruckBQ
    Brittney
    Thank you for all the info!! The reservoir was pretty nasty, we did the same type of cleaning, maybe I outta give it another cleaning.
  7. Nov 9, 2023 at 4:29 PM
    ControlCar
    Steven
    Sugar Land TX
    When did u RR p/s pump?
    recently?
  8. Nov 9, 2023 at 4:33 PM
    TaCoTruckBQ
    Brittney
    Last week, and before that....2019.
  9. Nov 9, 2023 at 5:18 PM
    ControlCar
    Steven
    Sugar Land TX
    A firm
    Ok
    My experience with an autozone/Oriellys AM/RM p/s pump RR 2 months ago
    replaced it
    And had same ‘dead spot’ and lil bit of whining right after installing
    I searched and found some site that said
    ‘Give it 2 weeks to break in’
    As I didn’t want replace it again……
    I took the advice
    after 2.5 weeks, no whining no dead spot
    Working perfectly presently
    Also as I was thinking,
    That whine is a tell tale sign of a belt being not right tension.
    You referred to the tensioner being hit with hammer .
    Is the tensioner too fucked up to try to adjust?
    Let’s us know
  10. Nov 9, 2023 at 6:05 PM
    TaCoTruckBQ
    Brittney
    That's good advice,I'll wait the two weeks. Yeah, the tensioner pulley bolt wouldn't budge. We're going to pull it apart and see if we have to replace the whole pulley, or maybe just the bolt. I'm honestly not sure yet.
  11. Nov 9, 2023 at 6:46 PM
    ControlCar
    Steven
    Sugar Land TX
    Just bc I have done this in the past….
    There are 2 bolts on tensioner
    Adjuster and the lock bolt
    Praying that ‘hammer guy’ knew this
    I.E. could be as easy as tightening p/s belt
    GL
  12. Nov 10, 2023 at 5:09 AM
    TaCoTruckBQ
    Brittney
    Lol, 'hammer guy' did not know this, which might have been why he chose violence. Im going to look at my Haynes repair manual after work and see where his hammer hit. I'll take a photo and upload it later today so yall can see what I'm talking about.
  13. Nov 10, 2023 at 7:04 AM
    rocknbil
    rocknbil Well-Known Member
    Bill
    2003 Taco Ext Cab DLX TRD 4WD MT 3.4L
    Groaning is a sign you may still have air in the system, when I changed my rack I thought I was totally hosed it was screaming so much. It took at least 20 minutes to get it to settle down. I agree, start over, clean the system.
    With the truck on stands and the engine off you have to turn full left, full right multiple times. Still on the stands turn the engine on and repeat. You can probably skip this step since you've already been driving it.
    Get it off the stands and repeat, full left, full right, make sure the fluid level stays up while you do this. Eventually it should start to quiet down and will go away except for that little bit while when you turn it really hard all the way to one side or the other.
    ControlCar and TaCoTruckBQ[OP] like this.
  14. Nov 10, 2023 at 7:50 AM
    TaCoTruckBQ
    Brittney
    Yeah, starting over is my best option....I feel like im in a tangle of wires at this point. Thank you for all the advice, I appreciate the help tremendously
  15. Nov 10, 2023 at 2:43 PM
    ControlCar
    Steven
    Sugar Land TX
    make sure and let everyone what happens!!!
  16. Nov 11, 2023 at 12:37 AM
    TaCoTruckBQ
    Brittney
    Yes, I will. I work a lot so I'll post asap
