Power steering problems
Discussion in '1st Gen. Tacomas (1995-2004)' started by Wpashe, Feb 13, 2024.
  1. Feb 13, 2024 at 10:23 AM
    Wpashe
    Wpashe [OP] Member
    William
    Tacoma TRD
    None
    I have a 2001 TRD. A few weeks ago my power steering went out. I changed the pump but that didn’t help. I next ordered a new rack and had it installed. Now power steering is fine but the pump makes a loud noise when I turn the wheels. (I had put power steering fluid in it where it should have been transmission fluid.) Transmission fluid was used with the new rack.
    Mechanic says I might need a new pump so I just installed a new pump and the noise is still there. I have turned the wheels lock to lock several times and it doesn’t help. Anyone got any idea what to do?
  2. Feb 13, 2024 at 11:39 AM
    Skulking
    Skulking Well-Known Member
    San Jose, CA
    1998 Xtra Cab v6 4x4 Manual
    Can you be more specific about when you hear the noise? Is it constant, only when you are actually rotating the wheel, or only when you approach full lock? A video of the noise would probably also be helpful.
  3. Feb 13, 2024 at 12:53 PM
    Wpashe
    Wpashe [OP] Member
    William
    Tacoma TRD
    None
    The noise is mostly constant but is deeper in tone and louder when turning the wheels. Also when I hit full lock the noise stops. I’ll try to get a video later.
  4. Feb 13, 2024 at 1:52 PM
    Wpashe
    Wpashe [OP] Member
    William
    Tacoma TRD
    None
    I started the truck and backed up and pulled up many times going from lock to lock. It was still making the noise. I just went out to get a video and noise is almost completely gone. I guess this time it just needed to get the air out of the lines.
    Thanks for replying.
  5. Feb 13, 2024 at 6:37 PM
    Gyrkin
    Gyrkin Well-Known Member
    Wyoming
    2000 Tacoma TRD v6 5-speed
  6. Feb 16, 2024 at 4:13 PM
    Wpashe
    Wpashe [OP] Member
    William
    Tacoma TRD
    None
    I didn’t but realize that this is the one thing that’s been on each pump. I will pull it and clean it as soon as I can
  7. Feb 20, 2024 at 10:57 AM
    Wpashe
    Wpashe [OP] Member
    William
    Tacoma TRD
    None
    I took the reservoir off and cleaned the screen with parts cleaner and so far it’s quiet as a mouse. Thanks for the advice!!!
    Mainmoe02 likes this.
