Power steering probless
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tom/Daisy, Aug 12, 2018.
  1. Aug 12, 2018 at 7:11 AM
    Tom/Daisy
    Tom/Daisy [OP] Member
    2007 Silver Tacom
    none
    I have a 2007 Tacoma 4wd,6cyl with the SRD package. The power steering is very stiff & binds up when turning, left or right. I flushed the system and replaced the fluid. This worked for about a week as the steering was almost normal. I don't see any leaks nor is the pump making noise. I am leaning toward replacing the rack & pinion. Can anyone give me some ideas or suggestions before I replace the rack and pinion?
  2. Aug 12, 2018 at 9:02 AM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Check for posts regarding intermediate steering shaft.
    Jimmyh likes this.
  3. Aug 12, 2018 at 9:09 AM
    Skyway
    Skyway Well-Known Member
    Ande'
    St.Pete
    White 2009 regular cab
    Steering shaft U-joint
    Jimmyh likes this.
  4. Aug 14, 2018 at 7:53 AM
    CanadianYeti
    CanadianYeti Well-Known Member
    Kitchener, Ontario,Canada
    2014 TRD DCLB
    A friend has an 06 TRD with about 85-90,000 miles and it ended up being the rack after trying everything else. He had the same symptoms.
  5. Aug 14, 2018 at 8:24 AM
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    Mine has the identical issue - as others have already said, spray the intermediate steering shaft U-Joint with PB-Blaster, then spray it with White Lithium Grease. I sprayed mine about 4 weeks ago and haven't had the binding re-occur once the grease worked in. I'll respray it when necessary.
    For me, this is a low severity issue and the repair can be put off. When I replace the intermediate shaft next year (I'm not spending more time on repairs this summer), I will be adding a right-sized rubber Bellows to prevent road salt from corroding it again.
  6. Apr 13, 2021 at 5:13 PM
    TheHeyseed
    TheHeyseed New Member
    2001/2007 Tacoma
    I have a 2007 that was doing the same thing, binding at times, seems like more turning right. I flushed the system and it got better for a while, but now I have excess play in the steering. Will a bad half shaft cause this? I researched replacing the rack and that looks to be an expensive PITA.
    Thanks 4cyl 4WD 150 K miles
  7. Apr 13, 2021 at 8:35 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Yes if the universal is badly worn it will have excessive play.
  8. Apr 14, 2021 at 2:41 AM
    Marc70
    Marc70 Well-Known Member
    Marc70
    Northern Ontario
    2012 TRD Sport 4.0L, 6MT
    2” lift, ARB front bumper, steel rear bumper, Trail Gear weld-on sliders, aFe cai, 2lo kit, air bag suspension, RA Motorsports AL skid plates
    Try spraying the universal joint with a good lubricant (Fluid Film worked great for me).
