power steering pulley nut
Discussion in '1st Gen. Tacomas (1995-2004)' started by JustADriver, Jul 2, 2023.
  1. Jul 2, 2023 at 8:40 PM
    JustADriver
    JustADriver [OP] Well-Known Member
    1996 Tacoma 3.4L V6 2WD 5-lug AT 5VZ-FE
    I loosened the belt and have a little play on the PS pulley. It's not really bad but it might be causing a vibration and I'd like to get it off to see about replacing the pulley ($182) or just the bearing.
    Is there a tool or trick that works to break the 17mm center pulley nut free without an impact?
    I tried hitting the end of a breaker bar with a mallet, and it's still just turning the pulley.
    I can potentially jam something into a pulley hole and against the power steering pump, but I'm worried about damaging something.
  2. Jul 3, 2023 at 12:11 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    You can put a deep socket thru the hole on to one of the bolts to hold the pulley.
  3. Jul 3, 2023 at 10:50 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    My trick was break it loose while the belt is still on.
    A strap wrench around the pulley to hold it in place.
