power steering pully? bearing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DCtaco05, May 27, 2012.
  1. May 27, 2012 at 3:19 PM
    DCtaco05
    DCtaco05 [OP] Well-Known Member
    dustin
    petaluma
    05 tacoma trd
    bone stock.. not for long
    2005 v6 tacoma pre-runner
    ok guys i have that pulley/whining sound. so i did a search here. I am doing the take off the serpentine belt and spin the pulleys. They all seem fine except for the power steering one. it has a little bit of "play" (towards the back and front of the truck) and it also doesn't spin as freely as the others. It stops pretty quickly. And i can also hear click/small knock when i turn that pulley.
    Now this should be my problem right? any input? is it the bearing the pulley?
    thanks for your help
  2. May 27, 2012 at 4:26 PM
    Coupe
    Coupe Well-Known Member
    Houston, Texas
    08 X-Runner
    Lots baby!
  3. May 28, 2012 at 9:07 AM
    DCtaco05
    dustin
    petaluma
    05 tacoma trd
    thanks for the idea but there is no leaks at all on the truck. i have a feeling it might be one of the bearings.
  4. May 28, 2012 at 11:24 AM
    joes06tacoma
    Joe
    Central Coast, CA
    More likely to be one of the idler or tensioner pulleys. Especially if it's been wheeled or taken in the mud. I have found that some PS pumps have some play in them. I've bought rebuilt ones that STILL have some play in them. I would not be in a hurry to replace that pump unless you've eliminated everything else.
  5. May 28, 2012 at 11:49 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
  6. May 28, 2012 at 7:29 PM
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
    The lucas product also will quiet a noisy p/s pump.
