Power steering pump gpm
Discussion in '2nd Gen. Tacomas (2005-2015)' started by allenn, Mar 31, 2023.
  1. Mar 31, 2023 at 11:49 AM
    allenn
    allenn [OP] Well-Known Member
    2020 TRD Pro
    How many gpm does a 2011 power steering pump put out? I use to have a hydraulic winch 9000# on my 05 thinking about 12k for my 11 if I have enough gpm.
  2. Mar 31, 2023 at 7:57 PM
    caribe makaira
    Caribbean, Puerto Rico
    I don't it changed from an '05 to '11.
    What did you add for it? An additional pump or a manual valve with filter?
  3. Mar 31, 2023 at 8:36 PM
    allenn
    2020 TRD Pro
    On the 05 nothing but only had the 9,000# mile marker and it worked flawless. I’m wanting to put a 12,000# on the 11. I don’t know if it takes more flow or not than the 9,000 I need to do some research. 9,000 was plenty for the Toyota but I’m usually Lully stuff out other than myself is why I want the 12,000
  4. Apr 4, 2023 at 4:29 AM
    allenn
    2020 TRD Pro
  5. Apr 4, 2023 at 4:51 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Never dealt with hydraulic winches before. The PS pump puts out enough flow & pressure at idle to run the 9k?
  6. Apr 4, 2023 at 5:11 AM
    allenn
    2020 TRD Pro
    Yes. Back when I had one according to the specs and research the power steering pump worked harder in 4wheel high vs a full load on the winch. It was nice having and hydraulic if you was going to be doing a lot of winch. Winch don’t get hot and no pull on your alternator. Downfall you can’t winch if the truck isn’t running, but you ain’t going to winch far with electric if the truck isn’t running either.
    SR-71A[QUOTED] likes this.
