Power steering pump hell
Discussion in '1st Gen. Tacomas (1995-2004)' started by cynicalrider, Jul 23, 2016.
  1. Jul 23, 2016 at 7:27 AM
    cynicalrider
    cynicalrider [OP] #NFG
    Jersey
    Alright so I got an A1 Cardon Reman power steering pump from Rock Auto. Fixed my whine and lasted about a year. I had a whine come back and since it had a 3 year warranty I got a new replacement warranty unit. This one didn't even last a month now. I would hate to keep replacing pumps so I am thinking of getting a new OEM one. If I do will this one survive? Maybe do another reman and throw an inline filter on? It's not a huge job but it's a pain in the ass to keep replacing/bleeding the system.
    My biggest worry is shelling out the cash for an OEM unit only to have issues again. @Dirty Pool you seem to know all about our trucks steering systems, any recommendations?
  2. Jul 23, 2016 at 7:30 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Get a new Denso unit.
  3. Jul 23, 2016 at 11:09 AM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    Have you cleaned the screen at the bottom of the tank? Could be starving the pumps if not
  4. Jul 23, 2016 at 2:17 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Knock on wood I have never had power steering Issues.
    Then I only run 235/75/15 tires on my Toyota fleet
    Then the quality of Cardon has gone down quite a bit .
    What about rebuilding a OEM pump ??
    It is not that hard
  5. Jul 23, 2016 at 3:31 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    I have gone through pump issues before, (replaced 3 of em after the oem one went titts up)drove me bonckers replacing pumps one after the other. One thing as mentioned already is making sure the screen is clean in the reservoir! If that is good as was mine, it ended up being the rack! It seemed to perform okay, at low rpm the steering was a wee bit hard but nothing serious. I noticed the fluid was very hot after driving for a bit. Everything was super hot, the lines, reservoir, everything! So i finally broke down and bought a rack and that was the problem the whole time! I think there was an issue with a check vakve er something and it was letting fluid by and under such high pressures it dosent take long to start creating serious heat from the fluid pissing by the valve under heavy load. I think the heat was killing my pumps. Bought a rack and my napa pump has been fine ever since. I know you dont wanna hear it but it could be your rack, its a strong possibility...
  6. Jul 23, 2016 at 5:35 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    I had this same pump issue. went through 4 pumps before i figured out that there was something clogging the rack. the pump i have now wouldn't work at low rpms. if i wanted to turn i would have to give some gas. then one day when i pressed the gas i heard a thud and all of a sudden my steering started working perfectly. you may have the same issue.
    however, put a filter on the return side! you can get these kinds of filters at napa. theyre your typical filter but it has a magnet inside to help catch particles. [​IMG] . put that on before you go any further.
    once you get a replacement pump on there, try being aggressive for the first couple miles with your steering, or just be aggressive right away. gas it and quickly turn the wheel from side to side. see if something happens like what happened to me
  7. Jul 23, 2016 at 5:38 PM
    cynicalrider
    Jersey
    Yeah I should have mentioned the rack is leaking as well. I replaced it with a safari reman 2 years ago, started leaking about a year ago. If I replace the pump with an oem one I was going to replace the rack at the same time. I want no steering issues if I head out to Moab next year.
    Also I cleaned the screen on the reservoir before I replaced the pump the first time and checked and made sure it was still clear the second time.
    For the dude who mentioned get a denso pump, I don't think I've seen them anywhere. Only seen aae and a1 cardone and some other brand.
    Trying to do everything right when it comes to this shit and still having issues ha.
  8. Jul 23, 2016 at 5:41 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I went through 2 aftermarket pumps. Both whined horrible right away. Oem now and zero whine
  9. Jul 23, 2016 at 5:42 PM
    CodeSeven
    Serge.
    Coachella Valley
    try this. after (prefferably) putting a filter on the return side, turn all the way to one side, gas it and try to turn it to the right a little more. turn it into the max its capable of doing. try to force it into blowing out whatever may be stuck in there. I don't think the pump is bad, it may just be clogged somewhere.
  10. Jul 23, 2016 at 5:46 PM
    cynicalrider
    Jersey
    I'll give it a shot. :thumbsup: I regret not putting a filter on when I installed the other pump. Maybe I'll flush and throw a filter on. And then do that too.
  11. Jul 24, 2016 at 9:19 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    I can't add much beyond what has already been mentioned.
    From day one the Taco PS pumps have been temperamental to say the least and the commercially rebuilt pumps much worse. You are far from alone.
    It's kind of strange because they are beyond simple. I have had good luck rebuilding and using rebuilt pumps. These days I think companies seem to be "stretching" quality control limits so "luck" may be the operative word there.
    Now that being said, my personal truck is on the original pump at 250K. I always felt it was on the noisy side and changed out the fluid to synthetic at 500 miles. A member of TTORA had noticed the same thing and said the synthetic cured it. I could tell no difference. It still behaves and sounds the way it did on day one. I will say the synthetic stays new looking for ever and there has never been so much as a spec on the screen.
    Some rebuilds have been known to require the install of a filter for the guarantee to be honored.
  12. Jul 24, 2016 at 9:39 AM
    cynicalrider
    Jersey
    What is your preferred synthetic fluid? Still an ATF, correct?
  13. Jul 24, 2016 at 9:59 AM
    Dirty Pool
    99 XCAB V6 MT TRD
    Yes, full syn, Dex III.
    FWIW, Mobile 1, any name brand will be nearly identical.
    There was no difference in operation/sound.
