Power steering pump leak
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GrayYota, Dec 19, 2018.
  1. Dec 19, 2018 at 6:47 PM
    GrayYota
    GrayYota [OP] Well-Known Member
    Todd
    16' 4X4 DCLB Magnetic Gray
    So I have a 2016 Tacoma double cab long bed with tow package with the V6, I changed the oil this weekend and noticed a fair amount of fluid on the passenger side frame and in a few other places .I followed the fluid back to the steering pump and it seemed to be coming from the metal line going into the pump. I cleaned everything up , ran the motor for a few minutes and turned the wheel back and forth a few times and didn't see a leak. After the truck sat for a few minutes there was some dampness around the line going into the pump. Took it to the dealer and they replaced the pump under warranty so all is good for now, little pissed this happened to a 3 year old truck, hoping its just a one time deal! The dealer said they made a note of it and will forward it to Toyota for future reference . So give your underside a good look next time you're down there, my steering was fine and there was plenty of fluid left in the reservoir , I'm not sure how long it had been leaking for but it wasn't something you would notice unless you had the skid plate off.
  2. Dec 19, 2018 at 6:59 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Sounds like you lucked out, usually when it's wet over there it's coming from the timing cover
  3. Dec 19, 2018 at 6:59 PM
    captainh00k
    captainh00k Well-Known Member
    Pittsburgh, PA
    2023 DCSB
    Same issue with my 2016. Had the ps pump replaced in early November because there was fluid on the bottom of the pump. Noticed a spot on the floor today, checked the bottom of the ps pump and it’s wet again. Dropping at the dealership tomorrow morning for the to investigate further.
    shakerhood likes this.
  4. Dec 20, 2018 at 5:24 AM
    btaco623
    btaco623 Well-Known Member
    Central Ohio
    '17 TRDOR
    Hood Blackout, 5100,LED Low's, SuperSprings
    Timing cover oil leak....have them put UV dye in the engine oil then check with a black light where it is leaking from. Timing cover leaks are happening to quite a few.
  5. Dec 20, 2018 at 1:27 PM
    captainh00k
    Pittsburgh, PA
    2023 DCSB
    Service advisor called and said the timing cover gasket is leaking. Have an appt for 1-7-2019 to have it replaced.
  6. Dec 20, 2018 at 3:35 PM
    shakerhood
    Southern Ohio
    That is a pretty involved job, hopefully they fix it up plus give you a loaner.
  7. Dec 20, 2018 at 3:43 PM
    captainh00k
    Pittsburgh, PA
    2023 DCSB
    They’re providing a loaner. Luckily I’m still under the 3/36 warranty. 3-4 day job from what they said.
  8. Dec 20, 2018 at 4:09 PM
    shakerhood
    Southern Ohio
    Sounds like you have a good Dealer there in the Burgh.
  9. Dec 20, 2018 at 5:52 PM
    captainh00k
    Pittsburgh, PA
    2023 DCSB
    Fingers crossed. Wish they would’ve figured it out the first time though
  10. Dec 21, 2018 at 8:30 AM
    btaco623
    Central Ohio
    '17 TRDOR
    My parts list is two pages long from replacing the timing cover gasket. It is a very invasive process that involved removing the engine in my case. I heard some had it done with the engine still in, some have had it removed. Play it on the safe side, open a case with Toyota and request a factory extended warranty. I got a look the internal paperwork, and the dealer cost for the repair in my case was around $3,000.00. Gone are the days where you can swap a 350 timing cover in about 30 mins I guess :(
  11. Dec 21, 2018 at 8:38 AM
    Clearwater Bill
    Billy
    Largo Florida
    :eek:
    :eek::eek:
  12. Dec 21, 2018 at 8:52 AM
    btaco623
    Central Ohio
    '17 TRDOR
    Better hope you never need to replace that timing belt!
  13. Dec 21, 2018 at 9:04 AM
    shakerhood
    Southern Ohio
    Chain?
  14. Dec 21, 2018 at 9:06 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Yes, chain.
    shakerhood[QUOTED] likes this.
  15. Dec 21, 2018 at 9:09 AM
    btaco623
    Central Ohio
    '17 TRDOR
    whoops! that what I meant to say...I totally knew that.
  16. Dec 21, 2018 at 11:30 AM
    captainh00k
    Pittsburgh, PA
    2023 DCSB
    @btaco623 - How long ago did you have the timing cover gasket replaced? Did it resolve the issue? Have you had any issues related to the repair?
  17. Dec 21, 2018 at 12:41 PM
    btaco623
    Central Ohio
    '17 TRDOR
    I've only put about 700 miles on it since the repair. I see no leaks at this point. Trans seems to be shifting harder 1-2 with noticeably more shudder as well...could just be the cold weather since it's return, but I'll be keeping and eye on it. Also had the dome light pop out, looks like it was broke when they fixed the leaking 3rd brake light some time ago. Rare to see something NOT get broke when the entire truck has been taken apart for one reason or another. That's all for now, but i'm sure more problems are coming.
    Edit- Those are the only issues related to the repair for now...still fighting some that were present before the repair as well
  18. Dec 21, 2018 at 12:46 PM
    captainh00k
    Pittsburgh, PA
    2023 DCSB
    I'm sure (hoping) the tech that repairs my tacoma is a senior tech. I know they're experienced and frequently perform more complex repairs without issue, but I'm concerned other problems will be created from this repair. I purchased certified pre-owned so I have a powertrain through Toyota for 7/100k so hopefully that will cover anything that may come up.
  19. Dec 21, 2018 at 1:11 PM
    btaco623
    Central Ohio
    '17 TRDOR
    I asked my Toyota case manager to request only the master tech do the repairs. Seemed like she had done that before many times and happily agreed to communicate that request to the dealer. However, you never really know who touches it once it goes in.
