Power Steering Pump - need diagrams / install instructions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Spif, May 6, 2018.
  1. May 6, 2018 at 6:40 PM
    Spif
    Spif [OP] vehicle: 2014 Taco 4x4 double cab
    2014 Taco 4x4 double cab - 125k miles
    2014 Taco 4x4 6cyl 6speed
    My power steering pump failed and I NEED to fix it before work on Tuesday morning.
    I have the new pump and filter.
    The pump comes with a bunch of gaskets and an inline filter and a manual that says, essentially, “Make sure you install all the parts properly and use all of the proper procedures.”
    Thanks for that.
    The videos I’ve seen do not go into the detail of what gaskets /washers go where, nor do they bother with the inline filter part.
    1) Are there any detailed how-to’s on this particular task that you can point me to?
    2) Can anyone post shots of any helpful service manual pages that I can reference for my work in the morning?
    I will be ordering manuals tonight online for later reference, but they won’t arrive in time to help.
    Thanks!
  2. May 6, 2018 at 6:52 PM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    How did this happen on a 2014?
    Haven't heard of many if any failures
  3. May 6, 2018 at 8:51 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
  4. May 6, 2018 at 8:59 PM
    Bishop84
    Bishop84 Well-Known Member
    I personally wouldn't use the filter, we throw them out with the reman units. Fresh fluid and a good install is all it needs, don't want a failing point beyond that.
  5. May 6, 2018 at 10:08 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
  6. May 7, 2018 at 5:17 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Did you buy a new or a reman? If it’s a cardone reman I wouldn’t even bother installing it.
  7. May 7, 2018 at 5:19 AM
    Spif
    Why not use the filter?
    Does it have negative impacts?
  8. May 7, 2018 at 5:23 AM
    Spif
    Yes, it’s a Cardone remanufactured pump. It was the only one in stock in my local stores.
    Can you elaborate?
    Cause I need my truck working tomorrow morning. Not installing something today is not an option for me.
  9. May 7, 2018 at 5:38 AM
    Bebop
    Nick
    Cardone pumps rarely work. They are either noisy or leaky. But hey, you might just get lucky. Usually I go through 3-4 cardone products before I get a good one. I always go with a new one.
    Spif[QUOTED][OP] likes this.
