Power Steering Pump Pulley (44311-04011)
Discussion in '1st Gen. Tacomas (1995-2004)' started by bobskinner, May 2, 2024.
  1. May 2, 2024 at 7:00 AM
    bobskinner
    bobskinner [OP] New Member
    1998 2.7l 4cyl Taco
    Hi, I've done quite a bit of searching but can't seem to find a solution to my power steering pump pulley problem.
    On my 98 Tacoma 2.7l 3RZ, I managed to slightly bend the power steering pump pulley while trying to back out a bolt through one of the holes in an attempt to remove the pump to get my cylinder head off. I should have quit when the bolt became hard to turn but I didn't... The socket was pressing into the back of the pulley, which I only realized too late.
    It seems the pulley (44311-04011) has been discontinued.
    Does anyone know if there are any other pulleys that might fit this power steering pump? Or is there a pump assembly with pulley that I can easily replace the existing one with?
    I am extremely frustrated with myself and at a bit of a loss as to how I can go about rectifying my mistake to get my truck back up an running.
    Any help would be greatly appreciated!
  2. May 2, 2024 at 7:04 AM
    mlcc
    mlcc Well-Known Member
    Oregon
    2002 DC TRD/ 1995 4runner
    Mid travel, armour all around
    On my 3.4 swapped 4runner the donor truck was in an accident and the power steering pump pulley was bent. So I took it off and bent it back as best I could. It still wobbles but i haven't had any problems since and its been years.
    cornbread_wy likes this.
  3. May 2, 2024 at 7:30 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
  4. May 2, 2024 at 8:46 AM
    bobskinner
    1998 2.7l 4cyl Taco
    Thank you for the replies and the link!
    I might try my hand at straightening the pulley before buying a new one.
