Power steering pump pulley
Discussion in '2nd Gen. Tacomas (2005-2015)' started by paskanaama, Mar 18, 2017.
  1. Mar 18, 2017 at 5:17 PM
    paskanaama
    paskanaama [OP] Well-Known Member
    2006 SR5 Tacoma Manual
    is there a way to get just the pulley for a power steering pump? The pulley on my truck is a little bit wobbly, but the pump itself seems fine. Would be nice to be able to just change the pulley. Looked on rockauto, and no luck with finding just a pulley.
    Thanks!
  2. Mar 18, 2017 at 10:15 PM
    marinetaco
    marinetaco Well-Known Member
    Bobby
    2005 Tacoma TRD
    If it's wobbly, it is probably the pump shaft wobbling. Will need to replace the pump.
    07 sport 4x4 likes this.
  3. Mar 19, 2017 at 5:27 PM
    paskanaama
    Good to know. Not making any noise yet, so have some time to go still
  4. Mar 19, 2017 at 10:17 PM
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    For both the V6 and the I4 the pulley and shaft are referred to in the FSM as a "sub-assembly", there is no procedure for removing or replacing the pulley in either pump's rebuilding. As has been said run it 'til it needs replacing--$125 or so for a rebuilt from RockAuto...
    REDdawn6 likes this.
