power steering pump removal---HELP!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Baby, Dec 31, 2009.
  1. Dec 31, 2009 at 12:53 PM
    Baby
    Baby [OP] Member
    Novato, CA
    03 Tacoma 3.4
    Replacing belts on a 2003 v6. Loosened the adjuster nut on the PS pump. Exactly what other bolt(s) do I need to loosen to get the pump to budge? I've looked at several explanations on the net and still can't figure it out.:confused:
  2. Dec 31, 2009 at 5:07 PM
    kevhogaz
    kevhogaz Low Speed, High Drag
    Queen Creek, Arizona
    SR5 PreRunner
    3" lift front & rear, Air Raid Intake System
    There's one on top, that I access with an open end wrench. It sits kind of behind the top of the pulley.
    If you move the airbox out of the way, you can get a socket on the adjuster bolt a lot easier than if it's in the way.
  3. Dec 31, 2009 at 5:34 PM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    Actually, you don't need to remove any bolts.
    Take the airbox out. The actual tension bolt is under the pump's banjo bolt. now right behind the pulley there is nut that you must loosen to move the pump. This nut keeps the tensioner bolt from loosening. once you loosen those two you will rotate the entire pump and reservoir counter clockwise. this will allow you to remove the belt.
  4. Jan 4, 2010 at 11:39 AM
    Baby
    Baby [OP] Member
    Novato, CA
    03 Tacoma 3.4
    Thanks, guys! All sorted.
