Power steering pump replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by FirstGenGem, Nov 15, 2016.
  1. Nov 15, 2016 at 7:03 PM
    FirstGenGem
    FirstGenGem [OP] New Member
    john
    Pittsburgh, Pennslyvania
    Single cab 1999 Toyota Tacoma 5speed
    The power steering pump in my 1999 Tacoma recently failed. While searching for a replacement pump, I've found parts with prices that vary from roughly $80-$300. Does the quality of the pump directly effect the steering performance? Basically, would I notice the difference of buying a higher quality pump, opposed to an inexpensive one?
  2. Nov 15, 2016 at 9:09 PM
    96Tacoma4WD
    96Tacoma4WD Well-Known Member
    So Cal
    1996 Toyota Tacoma V6 2dr Extended Cab 4WD SB
    Alpine head unit and CD changer
    Toyota parts only - you get what you pay for. Search the part on Camelback Toyota parts and then ask your local dealer to match it.
  3. Nov 15, 2016 at 10:38 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Im also one to stick with toyota parts but due to the extreme price of a new oem pump i went with a napa one and have been pleased by the performance, its just as quiet and has lasted a lil over 2 years at this point pushing around 33 inch tires...again i like genuine toyota but the price for that unit was just too much for my wallet at the time...
  4. Nov 16, 2016 at 6:42 AM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    Yeah. An OEM one is over $300 isn't it? So I've heard. Haven't actually checked. I know a non OEM is around $125 - $150. Correct?
  5. Nov 18, 2016 at 10:29 AM
    bry838
    oregon
    Yeah i believe your numbers are right in the realm...
  6. Nov 18, 2016 at 6:18 PM
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    My pump failed once, I found a used one on here for 40-50$ and it has been great for 3 years.
    IMO, used oem parts are better than most part store reman stuff.
    Use some common sense when Looking at used parts and you will be fine
