Power steering pump reservoir O-ring???
Discussion in '1st Gen. Tacomas (1995-2004)' started by SpeedoJosh, Aug 8, 2013.
  1. Aug 8, 2013 at 10:36 AM
    SpeedoJosh
    SpeedoJosh [OP] Well-Known Member
    Florida
    2010 Access cab, Base, 4x4
    So I cleaned the screen in my power steering reservoir awhile back. Put the reservoir back on, and it's been steering great. One issue though is that there has been a slow leak from where the reservoir sits on the pump. Don't know if I lost an o-ring somewhere in the process or what.
    Anyone have a breakdown of the reservoir and the pump?
    I know there is an o-ring that goes in a grove on the piece from the reservoir that slides into the pump, but what about at the actual meeting surface between the pump and reservoir?
  2. Aug 8, 2013 at 10:51 AM
    SpeedoJosh
    Florida
  3. Aug 8, 2013 at 5:35 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    T'would appear there is only one o ring between the two, perhaps yours slipped out of its groove slightly on installation? It's a pretty easy thing to happen
  4. Aug 8, 2013 at 10:15 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    My 99 FSM only shows one o-ring.
  5. Aug 9, 2013 at 5:45 AM
    SpeedoJosh
    Florida
    What really threw me off was that there was a sliver of an o-ring at the base when I took it off. Which made me think there was definitely one there at one point, but now it has vanished. But right before I installed the reservoir, I double checked the existing o-ring, and it had a sliver cut off. Seems like it was pinched off while putting it back on I assume.
    We'll see how well it holds fluid this time. If still leaking, I'll take it back off and throw on a bigger o-ring in the grove.
  6. Aug 9, 2013 at 7:55 AM
    tan4x4
    Rick
    Folsom, CA
    This o-ring is a one-use only, like most o-rings on our trucks. Don't re-use the old one unless you have no choice.
  7. Aug 9, 2013 at 8:37 AM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Just get a new one from the dealer, like $2 max
  8. Sep 14, 2015 at 11:02 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Did you ever end up ordering this o-ring or using a misc one? I took my reservoir off to clean it and now it's leaking too. I suspect it's also this o-ring.
  9. Sep 14, 2015 at 11:59 AM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    I had the same problem...I just used a generic o ring from an assortment kit I have. I even buggered up one when reinstalling, I found it to be beneficial to make sure and lube up the oring before reinstalling the reservoir to minimize "drag" on the ring while sliding it in.
