power steering pump screaming
Discussion in '1st Gen. Tacomas (1995-2004)' started by matthew5olson, Mar 18, 2010.
  1. Mar 18, 2010 at 8:53 PM
    matthew5olson
    matthew5olson [OP] Well-Known Member
    matthew
    pittsburgh, PA
    04 ext cab 3.4L 5spd 4x4 sr5
    K&N cold air intake, doug thorley headers, rear sensor simulator, flowmaster 40 series, magnecor plug wires, Royal Purple synthetic gear lube, airaid throttle body spacer, Hyperground system, flex-a-lite elec fan.
    my power steering pump was screaming. The fluid was low again. (i filled it up in nov because it was low) I put power steering fluid in it. as I put the cap back on I read that I was actually supposed to put atf fluid in it. the pump is still screaming and it is filled to the proper level. Do I need to drain the power steering fluid and put atf in it. Or did I ruin it by running it low. I also have the steering wheel at full turn way more then I should. can the pump be rebuilt (maybe toyota has a rebuild kit) or should I just get one from the junk yard. ( I assume one from a 3.4L 4runner will do?)
  2. Mar 18, 2010 at 9:16 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    your probably too late. I did the same thing a while back
    and I just rebuilt mine and it worked for about 5 days.
  3. Mar 18, 2010 at 9:19 PM
    vicstacoma
    vicstacoma Well-Known Member
    Victor
    Santa Maria, CA
    2000 Sr5 4x4
    Air raid cold air intake, procomp 7089 16x8 wheels, bf goodrich all terrain ko 265/75r16. Toytec 3" lift kit. Power slot rotors with posiquiet ceramics pads. Diff breather mod. LR Upper Control Arms.
    If i were you I would first drain the whole power steering system and refill it with the proper fluild(atf) and hopefully that will solve your problem.
  4. Mar 19, 2010 at 11:49 PM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    any update? did you try to drain it and refill with atf?
  5. Mar 19, 2010 at 11:53 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2014 DCSB TRD 4x4
    if you do have to replace it...the one from the 4r should work
  6. Mar 20, 2010 at 8:15 AM
    matthew5olson
    matthew
    pittsburgh, PA
    i did drain and refill it. I looked and found that its leaking around the gearbox. I filled it with atf and its still the same. my uncle (a mechanic) said that sound is air in the system somewhere. going to find the leak and see if I can bleed the system. Gonna take off the belt and see if its too hard to steer. If I can get along without it then grteat. It'll probably be way to hard though.
  7. Mar 20, 2010 at 6:57 PM
    biggdog747
    biggdog747 Well-Known Member
    MI
    taco
    yes they take atf but if im not mistaken you can put power steering fluid in it. the pump was bad before all of this. tacos dont have gear boxes they have racks. there are turn stops on the spindals that are steering stops so unless something broke you cant go past lock. go to a junk yard and get one and put it on.
  8. Mar 20, 2010 at 7:15 PM
    matthew5olson
    matthew
    pittsburgh, PA
    my uncle also agreed that power steering fluid would also do just fine. I think I just ran it to low for too long before I realized it was low.
