Power Steering Pump Squealing and Engine Overheating
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sikruis, Jun 5, 2025.
  1. Jun 5, 2025 at 10:43 AM
    sikruis
    sikruis [OP] Well-Known Member
    Scott
    2006 Tacoma Off Road
    Hey everyone, wanted to relate an issue that's appeared in the past few days since my engine swap. After replacing the serpentine belt the PS pump started squealing very loud. After a min or two it stopped. Figured it was just air in the line. I drove it all day that day with no issues. The following day, the squealing returned and the engine began to overheat. I flushed system several times with ATF. It's gotten progressively worse since and I cannot drive more than few mins without the engine immediately overheating.
    So, is it more likely the belt tensioner, the PS pump, or something else?
  2. Jun 5, 2025 at 10:57 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Was the water pump and or radiator replaced?
  3. Jun 5, 2025 at 11:02 AM
    TacoRob08
    TacoRob08 Well-Known Member
    Rob
    Fredericton, NB, Canada
    17 Sport DCLB
    gibson exhaust, OVTuned base 91, AFE intake
    is there coolant in it?
    sikruis[OP] likes this.
  4. Jun 5, 2025 at 11:03 AM
    TacoRob08
    Rob
    17 Sport DCLB
    seized water pump?
    b_r_o likes this.
  5. Jun 5, 2025 at 11:07 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Belt probably slipping on water pump because its seized
    Torspd likes this.
  6. Jun 5, 2025 at 11:19 AM
    MR5X5
    MR5X5 Well-Known Member
    ...PS pump definitely not causing engine overheat.
    Torspd likes this.
  7. Jun 5, 2025 at 11:20 AM
    sikruis
    Scott
    Nah, I figured it out. I forgot to mention I replaced the gaskets on the coolant exit. There must of been an air bubble in the engine. Replaced the coolant and G2G. The PS pump is still squealing, but have plans to rebuild.
    Torspd likes this.
  8. Jun 5, 2025 at 12:02 PM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    It didn't squeal until the new belt? Are you sure the belt is correct? Installed properly?
  9. Jun 5, 2025 at 12:07 PM
    sikruis
    Scott
    I think the tensioner is going out. It seemed a little loose.
