Power Steering Pump???
Discussion in '1st Gen. Tacomas (1995-2004)' started by kingston73, Dec 14, 2010.
  1. Dec 14, 2010 at 5:57 AM
    kingston73
    kingston73 [OP] Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    Just in the past couple weeks, after we had a cold snap and it was in the 20's and 30's for a week, I've noticed my steering has started making noises. Turning the wheel left or right it whines, but it only does this sometimes. I checked and have plenty of steering fluid, and from reading posts it seems like the power steering pump is the only thing that would be making noises like this. My question is this: is this a major problem or can I leave it go until/unless it gets worse? No leaks at all, never so much as a drop in the driveway.
  2. Dec 14, 2010 at 6:30 AM
    90YotaPU
    90YotaPU The Messiah
    Union County, NJ
    1990 Toyota 4x4 (Pre-Taco)
    Aftermarket Stereo, Spidertrax Wheel Spacers, HF Air Horns, 3" Lift
    Personally I would just leave it. Sounds like the pump from what you're describing. If worse comes to worse, if it officially goes out, you'll basically have old school manual steering. Not the worst thing in the world if you've driven a car / truck with it before.
    You may want to try changing out the fluid. It could be that the fluid is just getting so thick in the cold weather that it's not flowing through the pump easily. New fluid may help.
  3. Dec 14, 2010 at 7:41 AM
    kingston73
    North eastern Ohio
    09 SR5 4.0L 4x4
    One thing I forgot to mention that I noticed is the cap of the power steering fluid res. was pretty dirty, lily. Does that mean anything?
  4. Dec 14, 2010 at 7:50 AM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    3rd gen Tacoma
    Chicken lights, chrome and smoke tunes.
    I had mine replaced over the summer and now that its cold it whines pretty loud
    until the engine gets warm.
  5. Dec 14, 2010 at 8:07 AM
    TacomaJack09
    TacomaJack09 Well-Known Member
    Jackson
    Montana!
    06 Access Cab 4x4
    Billie 5100's, Ride Rite Airbags, Tech Deck
    Mine does this as well. My power steering hates cold weather! It sounds terrible when I start it, but after a few minutes its back to normal.
  6. Dec 15, 2010 at 6:34 AM
    kingston73
    North eastern Ohio
    09 SR5 4.0L 4x4
    I'd looked at the power steering fluid and level before I posted, and then went and bought new ATF III to add to the pump reservoir. I hadn't realized how dirty the old fluid was, new new stuff was a clear purple and the old stuff looks like hot chocolate, so I'll be flushing it and putting new fluid in it now. To flush it, am I just removing the rubber hose the travels from the res. down to the metal fitting at the bottom?
  7. Dec 15, 2010 at 7:29 AM
    Kuneff
    Kuneff Carpe Diem
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    I just flushed my fluids out and I have NO noise at all out of my pump... BUT it steers like there is NO power steering. Is it possible the pump is bad without making any whining noises? Or could it be hard to steer because of 5100's on the highest setting and 31 mud tires???
    Just doesn't seem to me that it would be the tires, maybe the 5100's changing the steering geometry.
    Any thoughts there?
  8. Dec 15, 2010 at 7:50 AM
    brelandt
    brelandt Well-Known Member
    Terry
    Dublin, CA
    04 Prerunner reg cab SR5
    3" lift front and back
    Mine made a lot of whining. But it was worse when I had my 3" spacer lift installed. I recently removed my spacers and the whining has gone down quite a bit.
    I did this samething about 3 years ago. Pump made a lot of noise and when I removed the spacer the noise went away for the most part. When it did whine it was very faint.
    I guess the Toyota pumps are just as bad as my old Fords I use to own. Nothing is worse than the Ford pumps!
  9. Dec 15, 2010 at 11:41 AM
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
    when my pump went out it didnt make any noise the motor ran like normal, it was just a b*tch to turn and impossible to parallel park i think i payed $170.00 for a new pump down at o'reilly's
  10. Dec 16, 2010 at 7:31 AM
    TacomaJack09
    Jackson
    Montana!
    06 Access Cab 4x4
    Before you flushed your pump did it whine really bad? How did you flush it? What did your old fluid look like?
    Sorry for all the questions, I just want to get to the bottom of this! Thanks!
    As for your question, mine feels the same way after my 5100 install. I have mine on the middle setting, with 31" All terrains. I think your correct when you say the steering geometry. The angles of the control arms have changed as well, which may be one factor too.
  11. Feb 17, 2012 at 11:47 AM
    pikuptruk
    pikuptruk Well-Known Member
    Vallejo
    01 4x4 2.7 Lifted
    6" Fabtech Lift 33" Tires Flowmaster Cold Air Intake
    Has anyone tried to rebuild their pump?
  12. Feb 17, 2012 at 11:56 AM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    im going to attempt to tear in to my old pump when i get my new one on
