power steering question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jeff OB, Dec 5, 2020.
  1. Dec 5, 2020 at 7:12 AM
    Jeff OB
    Jeff OB [OP] Member
    Ok, quick general question for you guys. I have a friend who a couple months back replaced a power steering line on his vehicle but didn't bleed the system of air. His car became hard to turn, particularly when just getting going. He said a mechanic informed him that he probably just had air in his system so I told him to take the cap off his power steering reservoir, jack the front tires off the ground, and turn the steering wheel back and forth to release air from the system. I helped him do this. However, while it seemed there were plenty of air bubbles coming up the fluid levels never went down. I know this is probably a bad pump or rack given that the fluid levels are fine, just was curious as to why the fluid wouldn't go down, even with bubbles coming up and air seemingly leaving the system? Thanks.
  2. Dec 5, 2020 at 7:47 AM
    CTSpruceMica
    CTSpruceMica Is a hotdog a sandwich?
    Dennis
    2014 Spruce Mica
    Air is compressible. The air trapped in the system does not take up much volume because it has been compressed. Releasing that compressed volume won't result in much change in fluid level.
    Jeff OB[OP] likes this.
  3. Dec 5, 2020 at 8:20 AM
    Jeff OB
    Jeff OB [OP] Member
    Thanks
