Power steering rack bushings... easy deal...
Discussion in '1st Gen. Tacomas (1995-2004)' started by rzgkane, Mar 25, 2013.
  1. Mar 25, 2013 at 7:46 AM
    rzgkane
    rzgkane [OP] Well-Known Member
    Huntington Beach, CA
    2019 Tacoma TDR Sport 4WD DCLB - Cement - Tech and Premium
    4Runner Trail wheels and Toyo Open Country ATII tires 265-70-17. Cosmetic stuff like Pro grille and OffRoad black bumper trim, vinyl delete on side, added hood graphic, OEM tube steps.
    I just replaced the struts and power steering rack bushings on my kid's 2000 Pre-Runner 2.7 with 160K on the ticker and it was a piece of cake. Prying the old bushings out was a little bit of a bugger but nothing unexpected.
    The Energy Suspension kit 8.10101G had the correct sleeves and everything pressed into place with almost no hassle. Just remember to support the right end of the rack using mechanic's wire or similar when you unmount it or it will hang down and be a bit of a hassle to manuever.
    For struts, I used a pair of Monroe Quick Struts that I got on ebay for $130 each complete; strut, spring, the whole deal. Four bolts and they fall out. For $275 this truck is tight again. The steering had become very sloppy and minor imperfections on the road caused the wheel to shimmy pretty badly. No more. Feels brand new.
  2. Mar 25, 2013 at 7:54 AM
    Kirk1589
    Kirk1589 Well-Known Member
    Dave
    Sticks-RI
    03 SR5 Off-Road
    Pasti-Dip Grille, K&N drop-in, Magnaflow 14", Custom tail light mod, Fog light mod, diff vent mod, Alpine Components, Sequoia JBL radio
    How do those quick struts ride
  3. Mar 25, 2013 at 8:46 AM
    rzgkane
    After driving the truck with original struts at 160K miles the Quick Struts seem like a slice of heaven. One of the old ones must have been totally shot because the steering wobble over road imperfections was horrible. Now, it's nice and tight with no discernable play at all. I think the Monroe's were just what the doctor ordered. No spring compressor needed, all new rubber spring isolators, etc. Pop 'em in and bolt 'em down. All for $129 each including shipping to my door.
  4. Mar 25, 2013 at 8:51 AM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Poor kid didn't get a lift kit though.
  5. Mar 25, 2013 at 8:52 AM
    rzgkane
    Poor kid drives so Cal roads and never sees anything but asphalt. :)
  6. Mar 25, 2013 at 9:32 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Monroe sells Readylift pre-assembled struts under the Rancho brand. They cost slightly more, though.
  7. Mar 26, 2013 at 2:52 PM
    blakewhisenant
    blakewhisenant Well-Known Member
    Blake
    Oklahoma
    1995 Toyota Tacoma 4x4 V6
    lots to come...
    I picked up some complete struts off of ebay for 87 bucks. Yes, for the pair, brand new.
    They ride alot better than the old stock stuff. Install was fast. Lets see how long that last...
  8. Mar 26, 2013 at 3:48 PM
    01kingtaco
    01kingtaco Well-Known Member
    Kodiak
    Maui hawaii
    01 taco slightly modded
    Bigger tires, sound system, deck plate mod, fog light mod, straight pipe exhaust, blue led floor lights, ultragauge, 3 inch lift
    Did u disconnect any of the tie rod ends when u did the rack bushings?
  9. Mar 27, 2013 at 6:44 AM
    C O R E
    C O R E Christian Off Road Engineering
    Clint
    South Texas
    03 TRD 4x4 5spd v6
    Line-X bedliner, bedlined toolbox, Satoshi Grille, bedlined stock old school wheels, Pioneer DEH-X9500BHS head unit, Deck plate mod, ISR mod, K&N Drop-in, Thrush muffler dumped @ rear axle, Grey wire mod, +5mph fender stripes
    My cousin and I just did this on his '98 and that wasn't necessary for us, just get the weight off the wheels, take the bolts loose, and have a friend put just a little weight on the tires to get the rack back just barely far enough to swap out the bushings. Don't pull it out too far and you wont have to worry about the hardlines attached to it getting kinked or broken.
  10. Mar 27, 2013 at 7:44 AM
    rzgkane
  11. Mar 27, 2013 at 7:51 AM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    Holy Walmart special...
  12. Mar 27, 2013 at 2:30 PM
    rzgkane
    Same here. No need to disconnect tie rods. Just wire support the right side of the rack around the area where the trans cooler lines meet the bell housing and you are in business. I am blown away how tight the new bushings and struts made this truck. If I could only cure the damn axle wrap all would be well with the world.
  13. Mar 27, 2013 at 9:13 PM
    01kingtaco
    Kodiak
    Maui hawaii
    Thanks for the info I gota do that this weekend
  14. Mar 28, 2013 at 5:59 AM
    blakewhisenant
    Blake
    Oklahoma
    lots to come...
  15. Mar 28, 2013 at 7:35 AM
    rzgkane
    I almost bought from them until I saw the listing said "Not for PreRunner." A call to them confirmed they do not carry PreRunner struts for my 2000.
    Edit: I just checked the cross reference to the Monroe numbers the guy lists on the auction page (Monroe # 171352L-171352R) and those are the numbers I installed on my 2000 Pre-Runner. May he just doesn't realize that his struts fit PreRunners.
  16. Mar 28, 2013 at 10:07 AM
    blakewhisenant
    Blake
    Oklahoma
    lots to come...
    They are forsure not as nice as some struts, but my truck is a Home Depot runabout... And thats about it...
    I installed the 3 inch lift spacers on top of them, and some blocks in the rear.
    Looks good. Also last weekend I added 2001 Tacoma rims and 265/75/16 tires.
