Power Steering
Discussion in 'Technical Chat' started by amaes, Nov 9, 2009.
  1. Nov 9, 2009 at 2:04 PM
    amaes
    amaes [OP] Cuz Stock Sucks
    Alex
    Phoenix, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
    Hey Guys,
    I was wondering how to flush my power steering system? It whines like a spoiled child and is starting to get annoying. The fluid is dark and it leaks about two drops per week on my garage floor. The level is fine but I want to clear it out and then find out where it is leaking from. Anyone know what the best way to fix this is?
    Thanks for the help,
    Alex
  2. Nov 9, 2009 at 3:36 PM
    amaes
    Alex
    Phoenix, AZ
    2011 FJ Built
    Bump
    anyone?
  3. Nov 9, 2009 at 3:48 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    First off, you need to find out where its leaking. YOu gotta fix that before doing a flush.
    I did a flush on my 96 - but it was a long time ago.
    First - check with your owners manual on what type of fluid you need.
    The 1st gen trucks use ATF as steering fluid.
    I bought a couple quarts of cheap/generic fluid for flushing with and the rest was synthetic ATF.
    Jack up the front end of the truck & open the hood. Get the appropriate jug to drain the fluid into. Basically, you open up the low pressure line and have it drain into a jug. Get someone to help you. As your buddy turns the wheel SLOWLY from lock to lock, you will pour cheap generic fluid into the resevoir. DO NOT LET IT GO DRY/EMPTY. The fluid should continue to pump out into the jug. Keep doing this until you've gone through a couple quarts of cheap fluid. Start pouring the good fluid into the resevior and when you're getting down near the bottom, connect the low pressure line and fill the resevoir to the COLD mark with the good fluid. At that point, have your buddy continue to turn the wheel lock to lock.... as you watch the resevoir. This is considered 'bleeding' the system. You should see bubbles come up into the resevoir. You need to keep the resevoir topped off and continue turning the wheel lock to lock until you don't see any bubbles come up (if you have any at all).
    THat's it in a nutshell. ATleast, that's how my husband and I did it.
  4. Nov 9, 2009 at 8:35 PM
    amaes
    Alex
    Phoenix, AZ
    2011 FJ Built
    Thanks Janster! Yeah i'll start looking for the the leak better now. I will most likely have the AZ crew help me out when we have our mod day. So You're saying I need to buy some cheap fluid and then after we have we run that through a few times we fill it up with the normal good stuff? I'm most likely just going to replace it with OEM stock fluid from Toyota. Its pretty cheap.
  5. Nov 9, 2009 at 8:46 PM
    Dane-Taco
    Dane-Taco Well-Known Member
    Justus
    Wasilla, AK
    '10 Doublecab 4x4 TRD Off-Road
    Bilstein 5100s set at 0, OME 886 coils, Camburg Ball-Joint UCAs, 295/70/17 Nitto Trail Grapplers on 17x9 Moto Metal 957s, 2" Tuff Country AALs, SX8000 Gas Shocks (Rear), Homemade Satoshi Grill, Redline Hood Struts, Locker Anytime Mod, Map Light Mod, Diff Breather Mod, Fog Lights Anytime Mod, Extra Bed D-Rings, Sock's Badges and Decals, PIAA 520's, Illuminated 4x4 Switch Mod
    Check the rack and pinion, slide your boots down if you have to. Had a similar issue with my old taco, fluid would fill my rack boots and leak out during turns. Took a while to realize where steering fluid was going. That whine sounds like you need to replace your pump. You can try a flush. (Has your pump run dry before?)
  6. Nov 9, 2009 at 8:49 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    If you need a hand finding the leak, let me know.
  7. Nov 9, 2009 at 9:17 PM
    amaes
    Alex
    Phoenix, AZ
    2011 FJ Built
    Nope its never ran dry or came close to running dry. It may not be that loud I just notice it maybe. haha
    Chris I will let you know if I can't figure it out.
  8. Nov 10, 2009 at 4:11 AM
    Janster
    Jandy
    Lancaster, PA
    The cheaper the better! Since you're just pouring it in and its coming right back out and you're throwing it away - don't waste your money on flushing with the good stuff.
    Do the 2nd gens use ATF?
  9. Jun 25, 2011 at 10:35 PM
    coastalbum100
    coastalbum100 Member
    97 tacoma 2.7 4wd
    be sure to take the reservoir off the pump and clean the screen in side the reservoir it stops up causing many many people to change pumps,rack and pinions,hoses and many hours of heartaches. power steering does not work after it stops up. u can bleed lines until your fingers bleed until u clean the screen. i think changing the fluid and cleaning the screen about every 75000 miles should be done.:cool:
  10. Jan 23, 2012 at 6:20 PM
    c005jjc
    c005jjc Statistics are boring…until you become one!
    East Tennessee
    01 Prerunner DoubleCab SR5
    Axle wrap mod, Fumoto oil drain valve, Tinted windows
    How do you get to the screen to clean it after you have taken the reservoir off? I also have the whine coming from the pump area. You can start it and after the fan quiets down, you can hear the whine. Turn the steering wheel just a little and it changes the pitch of the whine. I have done my first fluid change in the reservoir. Dark brown fluid that stunk to high heaven. After taking all the fluid out ofthe reservoir (put it in a clear water bottle so I could see what it looked like and if there was any sediments) with a neat little device called a Mix-Mizer (bought at Wally-world for around 4 bucks) I took a few Q-Tips and taped them one at a time on a small wooden dowl and gently tried to clean the screen as best as I could. I could see small particles lying on the screen although there weren’t alot of them. I got what I could with the Q-Tips and then started filling the reservoir. Doesn’t take very much fluid. Started the truck and did the back and forth with the steering wheel 8 or 10 times. Sounded like the whining wasn’t as loud. I have to take a 300 mile road trip over the next two days so when I get back I will do it again and see if it helps. Doing this over time would get all the old fluid changed to new but it would take a while. Thinking about taking the reservoir off and cleaning the screen and then doing a full flush…or maybe doing a full flush to get all the old out and then clean the screen. Any help on getting to the screen would be helpful?
  11. Jan 23, 2012 at 6:22 PM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    3rd gen Tacoma
    Chicken lights, chrome and smoke tunes.
    Most quick lube shops have a machine to do it (at least where I work we do) The service is $54.99 here and seems to work pretty well
  12. Jan 24, 2012 at 6:37 AM
    c005jjc
    East Tennessee
    10-4 I will check and see if any around here can do it. Thanks!
