Power steering
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ismael_Navarro, Mar 11, 2021.
  1. Mar 11, 2021 at 1:11 PM
    Ismael_Navarro
    Ismael_Navarro [OP] Member
    Ismael
    1997 Black Tacoma RWD
    Magnaflow muffler, cold air intake, LCE headers, throttle body spacer, short shifter, cat deleted.
    I found a leak in my pump for my power steering. I’m having a hard time finding a video or any instructions to how to replace the pump. I’ve seen and heard lots of things of having to change out the reservoir and just changing the pump alone I’m not quite sure. Any guidance and tips are appreciated thanks!
  2. Mar 11, 2021 at 2:05 PM
    king1217
    king1217 New Member
    2001 Tacoma PreRunner XtraCab
    EDIT: Just realized you have a 97, so info below likely doesn't apply to you. Rebuilding should still be cheaper though.
    I had a leak where the main shaft enters the pump and ended up rebuilding as it was much, much cheaper than a full replacement.
    I got Precision Power Steering Power Steering Pump Seal Kit Part #: 28401495 from O'Reilly's for $22.
    It's easy once you open it up, but I used Power Steering Pump Rebuild - Part 1 of 3 (1 Hand Mechanic) #SouthpawAutoworks - YouTube to walk me through it.
    Parts diagram here as well: 1996-2001 Toyota Tacoma Power Steering Pump 44320-04043 | Boch Toyota South
