POWER STRIP OPTION OR NOT?
Discussion in 'Tonneau Covers, Caps and Shells' started by VBGunner, Aug 10, 2017.
  1. Aug 10, 2017 at 3:34 AM
    VBGunner
    VBGunner [OP] Well-Known Member
    2015 Tacoma DBL CAB TRD SPORT
    I am getting ready to place and order for my new cap for my DCSB. I have the sport model with the built in inverter in the bed. Is getting the Power strip option (three Cigarette style plugs) worth it or advised? I know I have the inverter, but engine has to be running for that to work, thoughts? ideas? Thanks!!
  2. Aug 13, 2017 at 10:34 AM
    RichVT
    RichVT Well-Known Member
    Rich
    Northern Vermont
    2016 Tacoma TRD Off Road 4X4 AC Grey
    Only you can decide if you need or want a 12V outlet (or three) in the back of your truck.
    That being said, a couple of questions you might want to ask:
    1. Will the outlets be wired so that they are always live or will they only be live when something else is switched on (lights, ignition etc.)? Does that matter to you?
    2. Will they be tapping into an existing circuit to supply power to the outlets and will that circuit limit the amount of power that you can draw from the outlets?
    I added my own 12V outlet in the bed by running a heavy gauge wire directly from the battery so it's always live. I also added a pigtail for them to hook the cap lights to so I can use the lights when the truck is off. There's always the chance that I could run my battery down by leaving the lights on or leaving something plugged into the outlet but the convenience is worth it to me. Probably most useful if you use your truck for camping.
  3. Aug 14, 2017 at 8:28 AM
    VBGunner
    thanks Rich, allot of good input
  4. Aug 14, 2017 at 8:47 AM
    Blais03
    Blais03 Guess I'll bring a spare wheel bearing...
    Nick
    Easthampton MA
    '08 Reg. Cab 4WD + '06 Reg. Cab 2WD
    Personally I wouldnt use them so I think itd be a waste of money for me. But if you think youll use them then do it!
  5. Aug 14, 2017 at 8:50 AM
    VBGunner
    Bllias, that is my delimenia...I will camp back there occassionally....but dont know how much I would use...so weighing cost vs need...lol
    Blais03 likes this.
  6. Aug 14, 2017 at 9:21 AM
    Blais03
    Nick
    Easthampton MA
    How much extra does it cost?
  7. Aug 14, 2017 at 10:00 AM
    VBGunner
  8. Aug 14, 2017 at 10:03 AM
    Blais03
    Nick
    Easthampton MA
    yeah screw that lol
  9. Aug 14, 2017 at 11:42 AM
    cascadetaco
    cascadetaco Toyota Addict
    central oregon
    2017 SR 4cyl 4x4 5speed
    Wire it yourself...you will do a way better job then the canopy shop. I had to re-do or cover with loom all the wiring they ran to the front on my truck. They just haphazardly string bare wires barely zip tied to anything.
