Power supply
Discussion in '4th Gen. Tacomas (2024+)' started by Yelacloud, Sep 1, 2024.
  1. Sep 7, 2024 at 9:29 PM
    caribe makaira
    Caribbean, Puerto Rico
  2. Sep 8, 2024 at 4:49 AM
    Schlappesepple
    Schlappesepple Well-Known Member
    Joe
    2020 4Runner ORP
    Interesting, I thought they had a good reputation.
    What has worked well for you?
  3. Sep 8, 2024 at 9:52 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    You’d better charge a lot. While it is possible to provide a charge you’d have to be hooked up for hours with the engine running to add ten miles of range.
    I have a Dometic CF50 that’s been going strong for almost ten years. Been banged around all over the country and tossed around on sailboats in rough conditions. Flawless reliability and cold food/beer.
  4. Sep 9, 2024 at 5:35 AM
    gmtech
    gmtech Well-Known Member
    Iowa on the Mississippi
    2016 trd or. 2024 trd OR iforcemaxx!!
    Stock AF
    xoverland clip it says power inside and outside the cab. where is the 110v outlet inside the cab?
  5. Sep 9, 2024 at 7:29 AM
    snickers
    snickers My new, overpriced heaping pile of shit
    2024 Tacoma Tailhunter 5ft bed Bronze Oxide
  6. Sep 11, 2024 at 11:30 PM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    Sure.
    It’s interchangeable in common use for non-electricians. 110v/115v/120v and 220v/230v/240v are just various ways of referring to the same thing.
  7. Sep 12, 2024 at 5:11 AM
    gmtech
    Stock AF
    yea just didnt really know. if it has an outlet like that in USA does it matter what voltage it is? what ever you plug into it is prolly going to work and if it doesnt its not because of the voltage difference.
  8. Sep 12, 2024 at 7:38 PM
    rchrds
    rchrds Well-Known Member
    TN, USA
    2024 Trailhunter
    I'm 3 years in with an ICECO that has worked really well. It pulls the rated power for about 20 minutes when you first turn it on, then it slowly creeps down as it stays cool. Super happy with it, and it runs on both AC or 12 volt on the same machine. Comes with both cables. My only complaint is the interior metal film liner is not sealed in the corners (there might be a reason) so gooey stuff can creep in there.
