Power Tailgate Lock
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rrentrop, Sep 26, 2015.
  1. May 9, 2016 at 2:36 PM
    #281
    BruceH
    BruceH Well-Known Member
    Bruce
    Dallas/FT Worth Texas
    2016 Blazing Blue Pearl TRD Off Road 4x4
    I installed my Pop & Lock today using the video above as a guide. First, if you are going to order your Pop & Lock from Amazon, order the Positaps at the same time, it will save you some frustration. I didn't do that so I used the included wire taps which are difficult to get in the tight wiring bundle. I got it done, but like others have said, get the Positaps!
    I drilled holes in the tailgate clips as others mentioned and then ran the wire down the passenger side and then up through the grommet under the passenger seat. I made a small slit and then sealed it with silicone. The wire then runs under the passenger sill and into the kick plate. The kick plate has two white plastic clips that are angled? Try as I could, I could not get them to pop back in. I ended up taking them off. The kick plate is still plenty secure with the small nut and locking into the sill plate. I cut off the excess wire, making a neat install. I used more zip ties than what was included. All in all, it is a pretty simple install, it just takes time to run the wire and make everything neat.
  2. May 10, 2016 at 9:27 AM
    #282
    poppy510
    poppy510 Well-Known Member
    Rather than wiring to the door locks, I was thinking about wiring this up to a switch so that I can just lock and unlock from the cab as opposed to every time the doors lock/unlock.
    Anybody done this?
  3. May 10, 2016 at 5:22 PM
    #283
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    I think most people use the power lock buttons so they don't accidently forget to lock the tailgate.
    Deet likes this.
  4. May 11, 2016 at 6:02 AM
    #284
    muchostacos
    muchostacos Member
    Houston, TX
    2016 White DCLB TRD Off road
    I did the install following the instructions from Pop & Lock (Driver's side Pin 10-Black to Green & Pin 9-Blue to Blue) and the tailgate locks and unlocks when the Driver's door does regardless of the setting to unlock driver's or all doors. Does anyone know if there is another set of pins on the driver side I can use to get it to work on the double click?
  5. May 11, 2016 at 10:56 AM
    #285
    flesheatingvirus
    flesheatingvirus Well-Known Member
    ABQ, NM
    2016 TRD-OR 4x4AT Access Cab - Magnetic Gray
    Tech Package
    Noted for when I install one through the passenger side on my Access Cab.
    Thanks!
  6. May 11, 2016 at 12:31 PM
    #286
    neoflex
    neoflex Well-Known Member
    I had this issue as well.
  7. May 16, 2016 at 5:24 PM
    #287
    Wilstruck
    Wilstruck Active Member
    Will
    2016 TRD Off-Road
    In the planning stage
    Just finished install at a total cost of $15. Local shop charges $150 per door/ trunk. Stealership charges $250 for something that should be included from factory.
    MoQS likes this.
  8. May 16, 2016 at 5:35 PM
    #288
    MoQS
    MoQS Well-Known Member
    Merel
    Missouri
    MGM OR DCSB
    Details Please???
  9. May 16, 2016 at 5:41 PM
    #289
    Wilstruck
    Will
    2016 TRD Off-Road
    I only needed 20ft of 1/8 loom ($8 ebay) and a actuator (2/$6.50 ebay). I had everything else laying around my garage already.
  10. May 16, 2016 at 5:46 PM
    #290
    MoQS
    Merel
    Missouri
    MGM OR DCSB
    OK, gotcha. Thanks.
  11. May 17, 2016 at 8:52 PM
    #291
    Dano7891
    Dano7891 Member
    2016 Tacoma TRD Offroad 4x4
    Installed my pop and lock with the posi-taps (these things are awesome) and also had to set the wires green to green, blue to red. Didn't work at first and only had a few of the tailgate bolts out before I remembered that I didn't connect the wiring under the truck. Easy enough, not too loud, works like a charm.
    Dano
    George1441 likes this.
  12. May 20, 2016 at 6:10 AM
    #292
    JoeyDel
    JoeyDel Well-Known Member
    Joe
    South Jersey
    2003 Off Road AC and '16 AC Sport Silver Sky Metallic
  13. Jun 6, 2016 at 1:10 PM
    #293
    poppy510
    Installed my DIY electric tailgate lock actuator this weekend. Only cost $6 for the actuator, and had all the other bits laying around. Super easy...Do it!
  14. Jun 10, 2016 at 5:27 AM
    #294
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    It's more frustrating to know that Toyota could have done this from the start for such a low cost but chose not to.
    The only reason I can think of is that they wanted to have room to improve for the vet 2017+
  15. Jun 10, 2016 at 10:27 AM
    #295
    dilbert
    dilbert AI Member
    PNW
    2019 DCLB TRD Off-Road
    I'm looking for the correct wires to tap into so the tailgate solenoid will operate with the passenger doors on the second button press on the remote. Are these the wires for that functionality?
  16. Jun 10, 2016 at 10:31 AM
    #296
    poppy510
    Yep, behind passenger kick panel.
    dilbert[QUOTED] likes this.
  17. Jun 13, 2016 at 2:31 PM
    #297
    dilbert
    dilbert AI Member
    PNW
    Worked perfectly, thanks!
    Passenger side front, bottom Black connector (connect to red and green wire)
    GREEN (Pop & Lock wire) to GREEN (Harness), BLUE (Pop & Lock wire) to RED (Harness).
  18. Jul 3, 2016 at 9:36 PM
    #298
    renlo
    renlo Well-Known Member
    2019 TRD OR 4x4 DBSB A/T
    Just out of curiosity, will these actuators ever go bad? I mean, what if one day you go to unlock your tailgate and nothing happens, you wont be able to open your tailgate to swap out the actuator
  19. Jul 3, 2016 at 9:43 PM
    #299
    Dano7891
    Dano7891 Member
    Tailgate will always open with the key.
    Cheers!
    -Dano
    Deet, George1441 and renlo[QUOTED] like this.
  20. Jul 21, 2016 at 9:04 PM
    #300
    Aznray
    Aznray Member
    Ray
    Bay Area, Ca
    2016 Tacoma Trd Sport Dclb
    Hey everyone, I just wanted to show there is an alternative route to install a pop&lock, which I would consider the expensive route. What I did was instead of splicing/tapping into the factory harness, I ordered connectors and pigtail from Toyota to splice/tap into. This is what I would consider a safe alternative just in case you need to do any warranty work and can unplug the pigtail and plug the factory plug back in. The plugs and wires themselves cost about 100 and this is why I would consider the expensive route. Also you would need to solder the pigtails together and heat shink it. Here are some picture and part numbers just in case you as well wanted to go this route.
    Yann, KTJO 4x4, RioDiablo and 9 others like this.
