Power Tailgate Lock
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rrentrop, Sep 26, 2015.
  1. Oct 11, 2015 at 9:17 AM
    #41
    redacted
    redacted Member
    Don
    Longmont, CO
    2016 DCSB Barcelona Red TRD OR Tech JBL
    Thanks for the details @DOSS.
    Are those tied to the driver door?
    If so, does anyone know which color code would be tied to the passenger doors?
  2. Oct 11, 2015 at 10:45 AM
    #42
    rrentrop
    rrentrop [OP] TVDvinyldecals.com Vendor
    Rich
    Orange County, CA
    2016 Tacoma 4x2 Limited MGM
    T-Rex Billet Grille, N-Fab Steps, Tailgate decals, Bed Lights, Power Tailgate Lock
    Here are the color codes for the door lock actuators:
    Driver Door: B and R (before the J17 Junction connector) or L (after the J17 Junction connector)
    Rear LH: LA-R and LA-G (LA=Pink) <-- this is the one documented above.
    Rear RH: R and G
    Front Passenger: LG and R
    Hope that helps.
  3. Oct 12, 2015 at 4:42 AM
    #43
    DOSS
    DOSS Well-Known Member
    Scott
    Utah
    2016 Black Tacoma TRD Sport DBCB
    And just an FYI all of these can be found in the bundle in the A pillar that I pulled my connections from :)
    James_Bond likes this.
  4. Oct 15, 2015 at 10:04 PM
    #44
    tpak
    tpak Well-Known Member
    chris
    Colorado
    '16 DCLBOR JBL 4x4 Blazing Blue FTMFW
    Doss, I was just killing a few minutes thinking about this and based on Jeffs comments I searched around and found a Tundra write up that did the same but used direct attatch more like the Pop & Lock solution but with an $11 ebay actuator. Do you think this would work? Might be nice solution rather than drilling. I might give it a go for $11 + wire parts etc. have a look and let me know.
    Project page (note - he also goes crazy and adds 2 extra actuators like Doss' to actually open the gate - very clever)
    Fleabay actuator: (search for 524N if the link is expired)
    http://www.ebay.com/itm/Directed-DE...hash=item23513e3ad3:m:m4pCIIagtHhBnHuYpt8IS0A
    #44
  5. Oct 16, 2015 at 1:22 AM
    #45
    TayTay Ankles
    TayTay Ankles Well-Known Member
    This looks like I would be in over my head if I tried this. I'm a Youtube kid, you should really make a video or a youtube channel!
    MN5oh likes this.
  6. Oct 16, 2015 at 1:31 AM
    #46
    TayTay Ankles
    If you are about to take on this project, someone make a youtube and post it on here since Doss already did his install.
  7. Oct 16, 2015 at 5:52 AM
    #47
    DOSS
    Scott
    Utah
    So looking at that I worry that it would cause the actuator to fail early due to the fact that the actuator will end up moving a little bit each time to account for the rotation of the lock arm. Normally this rotation is absorbed by the rod that you use to connect the lock arm and the actuator.. I dunno just spit-balling linear and rotational forces issues here.. I also don't know how well that little nub of plastic that is used for connection to the lock will hold up... the actuator is always going to push and pull further than this was originally intended to go so there may be some potential for that snapping off and if it did in the lock position that would seriously SUCK... I think it would work though...
    A couple suggestions though - 1 When he makes the bracket he keeps the open end down.. don't do this your actuator is probably going to move this braketry some and will cause it to rub on the inside of the tailgate (can you say rust). 2 put some thick foam rubber under this bracket to deal with the movement and protect the inside of your tailgate even more.
    #47
  8. Oct 16, 2015 at 10:20 AM
    #48
    tpak
    chris
    Colorado
    Good points. I was scratching my head a little bit on the way he mounted it.
    I stumbled into this b/c I was trying to figure out what actuator the Tundra's use and trying to see if I could find a cheap aftermarket version. Still need to finish that search. It'd be nice to find a plug and play solution but either the one offered on here or the one I found would work fine as well.
  9. Oct 16, 2015 at 10:21 AM
    #49
    tpak
    chris
    Colorado
    @Jeff Lange - could you please dig up the part numbers for the handle assembly and the actuator? [edit] - for the Tundra tailgate handle that you referenced - it'd be great to see if we can use the actuator or an aftermarket actuator -- thanks!
  10. Oct 17, 2015 at 2:33 AM
    #50
    Gingerbeard Man
    Gingerbeard Man Well-Known Member
    Jared
    North Dallas
    2016 MGM DCSB Sport 4x4
    Icon stage 3 tubular 285/70/17 Toyo ATII
    Can't wait to do this
  11. Oct 19, 2015 at 8:52 PM
    #51
    TayTay Ankles
    Is it the exact same as this video?
    https://youtu.be/z0TDgh0ug9k
  12. Oct 20, 2015 at 7:57 AM
    #52
    tpak
    chris
    Colorado
    I dont think so. That looks like it is moving the servo mechanism with the metal on it in front of the latch mechanism to also act like a lock on that '13 which does not have a lock in the first place. The '16 has a lock and DOSS is actually operating the lock mechanism if I understand correctly.
  13. Oct 20, 2015 at 9:26 AM
    #53
    rrentrop
    Rich
    Orange County, CA
    This is the video that I mentioned that motivated me to do this project. The actuator is different but the wiring is pretty much the same. If you want the Pop and Lock model search for the Tundra installation video. I understand that the handle and lock mechanism is the same on the 3G Taco so that model should fit as a no-drill installation.
  14. Oct 20, 2015 at 2:12 PM
    #54
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    Sorry, can you clarify what you mean?
    Jeff
  15. Oct 20, 2015 at 3:24 PM
    #55
    TayTay Ankles
    Ok, thank you.
  16. Nov 1, 2015 at 10:37 AM
    #56
    aggie77
    aggie77 Well-Known Member
    Georgetown, TX
    2016 Tacoma Ltd 4x4
    Lund Nerf Bars Auto tailgate unlock
    The wiring shown in the video was not the same as my 2016 double cab. The LR door lock wires in the B pillar were Lavender (pink)/Red and Lavender/Green in my truck. The fabric tape around the wire bundle was a bitch to get off and there was very little slack in the wires.
  17. Nov 1, 2015 at 11:54 AM
    #57
    Rememberthecaptain
    Rememberthecaptain Well-Known Member
    Eastern Washington State
    2022 TRD OR 6MT Tacoma. 2021 Venture Edition 4runner
    Look and see.....
    Subd for easy seeks
  18. Nov 1, 2015 at 12:43 PM
    #58
    TayTay Ankles
    Great... i probably wont be doing this. I'd need a better tutorial. Thanks
  19. Nov 1, 2015 at 1:24 PM
    #59
    smugly
    smugly Well-Known Member
    Doug
    2005/2009/2016 4x4 TRD double cab taco, and now a 2024 Trailhunter
    some and more and more and more and
    tagging
  20. Nov 3, 2015 at 11:13 AM
    #60
    jweir99
    jweir99 Well-Known Member
    Dallas, Texas
    On Order: 2016 MGM DCSB 4x4 TRD OR
    Sub'd
