Power Tailgate Lock
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rrentrop, Sep 26, 2015.
  1. Apr 21, 2018 at 4:16 AM
    #581
    RichVT
    RichVT Well-Known Member
    Rich
    Northern Vermont
    2016 Tacoma TRD Off Road 4X4 AC Grey
    I ran one wire from the passenger side and split it at the rear. I installed the tailgate lock first and left the other wire ready to go for the cap lock when I had the shell installed. Everything works fine.
  2. Apr 21, 2018 at 7:01 PM
    #582
    SQR74
    SQR74 Well-Known Member
    Austin, TX
    2018 Tacoma TRD Sport
    There is how i did the Sound Deadening Mat.
    Tibetan Nomad and tonered like this.
  3. Apr 21, 2018 at 7:26 PM
    #583
    Nettleberger
    Nettleberger Well-Known Member
    2017 Tacoma TRD Pro DCSB Super White
    Looks great. Just to clarify - you only applied it to the rear side of the tailgate just to that second 'bridge leg'? Nothing in the inside side or any of the cross pieces right?
  4. Apr 21, 2018 at 7:50 PM
    #584
    SQR74
    Austin, TX
    Yes, correct. Actuator mounted to the metal part and plastic handle, so this is where goes most vibrations, when actuator engages.
    I decided to cover that area around the tailgate handle.
    Nettleberger[QUOTED] likes this.
  5. May 3, 2018 at 6:41 PM
    #585
    AllGen
    AllGen Active Member
    Shawn
    Texas
    2016 Blue Tacoma Limited 4x4
    Hidden front bumper 32" LED light bar HID headlights Morimoto XB fog lights Pop and Lock for tailgate Metal oil filter housing Bed extender OE bed mat OE bed front rail for sliding hold downs Toyota first aid kit Bed cubby hole block offs Door seal protectors with aluminum inserts OE LED bed light pods and Matt Gecko LED strips OE TRD Pro grill Ceramic tint MESO gasshole and coin holder 1/2" Toytec front shock/strut spacer (leveling kit) 1/2" Toytec rear leaf spring shims with 7.5" u-bolts (leveling kit-IMO) Anytime front and rear camera Shapeway's drivers side cubby switch insert (anytime camera switch location)
    My pop and lock would hang up as well and not lock. I pulled my cover apart and tried repairing it a number of times before finally getting the right fix. I had some blind threaded rivets (#8 - 32 and ½” long) in one of my junk bins that came from, well I don’t know where they came from. I pulled the lock back out and used a 5/32 drill bit to drill out a hole on the pivot arm. I would recommend a punch/nail or smaller bit (pilot hole) to make a sure you get dead center when using the larger bit. There’s not a lot of extra material if you mess up. I would also suggest using Loctite. I believe the M4 threaded rivet is the metric equivalent and is readily available on Amazon or EBay. I don’t know if any of the local hardware stores carry these.
    Tibetan Nomad likes this.
  6. Jun 1, 2018 at 12:36 PM
    #586
    TJK
    TJK Member
    Todd
    2018 Tacoma TRD offroad
    Painted bumper caps, door scuff plates, hidden bumper light bar, adding factory tonneau cover
    For the wire nuts out there I'm planning on using posi-tap into the pink w/red and pink w/ green what is the exact wire size? I looked at the wires and just looking at the rubber it could be 18 or 20 gauge but that is the cut off do I get the red or blue posi-tap
  7. Jun 8, 2018 at 7:40 AM
    #587
    flipnidaho
    flipnidaho Well-Known Member
    2001 Tacoma Double Cab TRD
    I'd be interested in using Positaps as well when I do this mod. What size did you end up going with?
    TJK[QUOTED] likes this.
  8. Jun 8, 2018 at 8:21 AM
    #588
    sabre170
    sabre170 Well-Known Member
    Drew
    Earlier in this thread someone said blue ones. I haven't done this mod yet myself. I have all the parts....just need to do it. FWIW, I bought blue ones to use based on that previous posting.
    YMMV
    TJK likes this.
  9. Jun 9, 2018 at 6:51 AM
    #589
    TJK
    TJK Member
    Todd
    I still have yet to buy the taps i was waiting for a solid answer to the exact wire gauge, if I were to just guess based on what I saw the wire thickness would be around 20 gauge and I would pick the red ones, right at the cut off either way I'm sure you could get by with red or blue but I think if the wire were smaller than u may not get a solid tap with blue. I'm thinking if I went red and the wire was 18 gauge that at least the wire would be positively centered for the tap. FWIW I have never used posi tap but have done an absolute ton of wiring in my lifetime so take it for what's worth. If it were out side of warranty I would cut and use environmental splices but seeing how I have under 1k miles on it I'm trying not to make "permanent" alterations. Also look further on Amazon there is way better deals on the posi tap than the one previously linked 5 for 14$ is not a good deal. Here is 6 blue for 10$ https://www.amazon.com/gp/product/B00H242NNY/ref=ox_sc_saved_title_2?smid=A2Q32NH2TXUFG5&psc=1
    And here is 6 red for 10$ https://www.amazon.com/Lockitt-POSI...D=41Rxh4EGAiL&preST=_SX300_QL70_&dpSrc=detail
  10. Jun 9, 2018 at 7:08 AM
    #590
    flipnidaho
  11. Jun 20, 2018 at 4:08 PM
    #591
    runmc
    runmc Well-Known Member
    Ron
    DFW Texas
    2021 Army Green Tacoma TRD OR DCSB
    One Mod after another
    IMG_1437[1].jpg IMG_1436.jpg IMG_1434.jpg Just did my 2018 DCSB and it's wired green to green and blue to red. Works great! I did not use the connectors that were supplied. I bought the ones that clip onto one wire and then you put a spade plug on the other wire and plug it into the clip.
    This wayif your wires are crossed you can switch then easily. Be sure to push your wire down into the metal slot to be sure it makes contact.
  12. Jul 10, 2018 at 7:35 PM
    #592
    benkitesurfs
    benkitesurfs Well-Known Member
    Portland
    2018 TRD Off-Road MT
    Thanks @Aznray for this idea! I found the correct pins from Corsa https://www.corsa-technic.com/item.php?item_id=435
    Bought the housings from Toyota, and made my own wiring harness. About $25 in parts! I haven’t installed it on the truck yet, but the hard part is over, and I can rest easy knowing that I didn’t mess with my factory wiring harness at all.
  13. Jul 11, 2018 at 3:15 AM
    #593
    runmc
    Ron
    DFW Texas
    Very nice job! Thanks for the link. I think I'll redo mine. :thumbsup: What wiring harness did you tell Toyota?
  14. Jul 11, 2018 at 9:24 AM
    #594
    benkitesurfs
    Portland
    The housings are Toyota part numbers - courtesy of @Aznray:
    90980-11536
    90980-11537
    The pins were purchased from Corsa https://www.corsa-technic.com/item.php?item_id=435&category_id=144
    You'll need six of each type (pins and sockets), but I would recommend you get a few extras in case you screw a few up while crimping:
    090II-PIN2
    090II-SKT2
    And then you'll need some 16ga stranded wire from anywhere wire is sold...
    Vttroy, GF8er, Aznray and 1 other person like this.
  15. Jul 17, 2018 at 9:23 PM
    #595
    Spuente21
    Spuente21 Active Member
    Salvador
    Corpus Christi Tx
    2016 Tacoma
    20” Pro comp wheels on 285/55r20s mts Trd shift knob Bed mat Trd grille Two 30” Rigid light bars Trd Pro Fog Lights Predator steps Added painted rear bumper covers Meso gasshole 3” Pro comp lift kit
    Anybody tell me what color wires and people say it’s the bottom plug then I look and you tube and see people use the top white plug on the same passenger side and I’ve tried both plugs and the actuator still does nothing can’t figure it out might have to run then to the driver and give them a try on that side? TIA
  16. Jul 17, 2018 at 9:25 PM
    #596
    Spuente21
    Salvador
    Corpus Christi Tx
    2016 Tacoma
    Could you me on those instructions if still available I’m having trouble tapping them correctly
  17. Jul 20, 2018 at 8:14 PM
    #597
    badcrazy
    badcrazy Active Member
    CT
    2018 Grey Tacoma TRD Sport
    New joiner here - wanted to give back a bit, as I learned enough from this thread that I ordered a P&L kit tonight... In case anyone is interested, JC Whitney has the PL8535 kit for $82.47 plus free shipping (found coupon online). Beats Amazon by a good amount. I also ordered parts to build a P&P harness (Thanks
    benkitesurfs and @Aznray)!
    benkitesurfs and Aznray like this.
  18. Jul 20, 2018 at 10:22 PM
    #598
    axisofoil
    axisofoil Rocket Surgeon
    Gilbert, AZ
    2016 TRD OR Dcsb 4x2
    In case anyone is wondering....
    These seem to get finicky over 105degrees.
    I've had to go back to using the key, because it locks but won't unlock my tailgate when it's hot.
  19. Jul 21, 2018 at 4:24 AM
    #599
    flipnidaho
    Have you tried opening the tailgate back up to see if the mounting bolt have loosened up allowing for some slop in the mechanism?
  20. Jul 21, 2018 at 6:22 AM
    #600
    axisofoil
    Gilbert, AZ
    Not yet
    Did I mention that it happens when over 105? :p
    (lounging by the truck outside is not in the top six thousand things I want to do until like october)
    MunchTIME likes this.
