Power Tank or ARB
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 21TacoTRDPRO, Jan 30, 2022.
  1. Jan 30, 2022 at 2:03 PM
    21TacoTRDPRO
    21TacoTRDPRO [OP] Follow my IG @21toyoduh
    ordnaS
    SoCal
    21 Tacoma TRD PRO
    Exterior Gears: 5.29 revolution Lift: @Wescottdesigns UCA: @jbaoffroad Leaf springs: @ivdsuspension Wheels: @stealth_custom_series Tires: @yokohamatire Yoko MT Front Bumper @drtfabrication Rear bumper @outgearsolutions HC with tire carrier Roof rack: @Prinsudesingstudio w/2 Load panels 44" light bar Rock Sliders: @rcioffroad 20 BYND 4X4 tactical camper Bed stiffeners:@ChassisUnlimited @cali_raised_led P/S molle panels and Ditch light brackets Sequential led side mirror turn: @MesoCustoms Cat shields: @cali_raised_led Oil: @FUMOTO oil drain valve AC mod Rear Differential Breather: routed to fuel door CMC: @ironrynofabrication Fender Flare Trim: @21toyoduh Rock lights: @RoughCountry Hood scoop 12" LED amber / white + strove light bar Tailgate power lock/unlock: @toyotausa Hood Struts: @redlinetunninginc Rear recovery points: @nytop.store Rear sway bar: @progressgroupinc Tire carrier: Fishbone Offroad Interior Power Switch: @switch.pros.official Power tray: @powertrays @ragofabrication Center Console molle panels /bridge & wifey mount Footwell lights: @VLEDS front /rear + sunvisor vanity lights @Weathertec floor liners, in-channel guards, hood guard @DongarTechnologies rear view mirror USB @AJTDesign minimalist key fobs On board Air: @viaircorp 400P Wifey Air System CMD Center: @expeditionessentials @3TPAM 4x @RAMmounts GMARS: @MidlandUSA MXT275 GPS/Safety: @Garmin Overlander, Garmin Montana 700i
    I see that most of you guys run a arb single or twin air compressor system. My question is if the 10-15lb Power Tank is about the same price as the twin ARB but the Power Tank is like four times as fast to inflate four 35" tires. Why wouldn't you go with the power tank? I get that the power tank requires refilling. But isn't the game about getting back on the trail quicker?
  2. Jan 30, 2022 at 2:27 PM
    21TacoTRDPRO
    ordnaS
    SoCal
    21 Tacoma TRD PRO
    True;
    when I get a air system I'm going with the power tank
  3. Jan 30, 2022 at 2:38 PM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    I have the ARB air compressor and I installed the ARB tank which is tucked away behind (in front of?) my taillight. Best of both worlds if you're not using the monster valves (which likely most aren't with their power tank).
    Bumble Bee Tuna likes this.
  4. Jan 30, 2022 at 2:42 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    You can build a 10lb co2 setup for like half the cost of a power tank. Wont look as flashy but does the same thing. No real reason for their adjustable reg either.
    jonkassidy likes this.
  5. Jan 30, 2022 at 2:49 PM
    mquibble
    mquibble Well-Known Member
    Michael
    2021 TacomaTRD Pro
    I don’t have either yet but was dead set on the tank. I’ve recently changed my mind and have springtime plans to install an arb twin under the passenger seat. I like the fact that the compressor is relatively limitless and shaving a few minutes here or there isn’t a big deal unless I’m out in the rain. But I have a fix for that- shrimp boots and rain gear.
    You say cost is about the same but you are ignoring the recurring cost of refills.
    TartanEagle likes this.
  6. Jan 30, 2022 at 2:52 PM
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
    I have both. Powertank is cool, but shit gets old always needing to take it to be filled.
  7. Jan 30, 2022 at 4:21 PM
    Aardvark13
    Aardvark13 Sultan of Squeeze, Wizzard of Slide
    Byl
    Knoxville
    2014 DCSB OR
    Aardvark4x4 Built for Go
    Yeah the powertank is kind of big and bulky and heavy. I dont have an arb but I do have both a power tank and a compressor which is not mounted. A day or weekend out wheeling maybe I take the tank, longer trips I take a compressor. I bought a propane tank thats about the same size as my tank so I can mount either in the same carrier. I just haven’t been able to justify spending $600 for an arb when my $150 portable compressor has been fantastic.
  8. Jan 30, 2022 at 4:28 PM
    NMBruce
    NMBruce Well-Known Member
    SW Colorado
    2020 Quicksand TRD OR, sold = 2006 GX470 (past 85, 2-1987 pickups,90, 92, 96 pickup, 2000 xtracab, 2002 double cab)
    Ironman Foamcell 3" lift, ARB dual compressor, GoPro mount, BadElf mount, Drive grab handle, RCI skids, Victory sliders, half rack, TuffStuff Alpha ll RTT, Dometic 75 Fridge, extra USB & Outlets
    hope it works for you
    I like my ARB, I have had it now over 5 years and two different vehicles. Once I filled up my 4 tires & 2 trailer tires, plus 3 other vehicles and another trailer.
  9. Jan 30, 2022 at 6:17 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    ARB for general airing up and locker actuation. Tank on standby to seat beads and run tools... when I remember to get it filled.
  10. Jan 30, 2022 at 6:30 PM
    Aardvark13
    Byl
    Knoxville
    2014 DCSB OR
    I thought thats what wd-40 was for? :welder:
    Junkhead likes this.
  11. Jan 30, 2022 at 6:34 PM
    ShimStack
    Ben
    NC
    I prefer starting fluid. :bananadead:
    Junkhead, Skydvrr and theesotericone like this.
  12. Jan 30, 2022 at 6:35 PM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    Or brake cleaner. WD-40 doesn't light for shit.
    Junkhead and Skydvrr like this.
  13. Jan 31, 2022 at 2:42 AM
    Aardvark13
    Byl
    Knoxville
    2014 DCSB OR
    You just gotta light it while you are still spraying. Also keeps the mosquitoes away.
  14. Jan 31, 2022 at 7:34 AM
    MR E30
    MR E30 Well-Known Member
    Michael
    Wherever it's parked
    2021 Silver TRD OR DCLB w/ AluCab and All the Mods
    I've also had both. Started with the Powertank and ended up with a dual ARB, which I prefer much more.
    In every instance, the extra speed of the Powertank was worthless, as everyone else I was wheeling with used ARB's. So, I finished faster, but it didn't mean anything, as I wasn't going to leave my friends behind.
    Powertank is much too bulky as well. Mounting it was more painful. You also always had to keep in mind that you were transporting highly pressurized stuff around with you, in a vehicle that was getting jostled around and tipped side to side and forward and back.
  15. Jan 31, 2022 at 8:05 AM
    TexasTacoLT
    TexasTacoLT Well-Known Member
    Killeen, TX
    '14 TRD Offroad
    3" Lift (ToyTech Coilovers and AAL) Bilstein 5100 Shocks Total Chaos UCAs Method Double Standard 17" BFG All-Terrain T/A KO2 (Removed) 33" BFG Mud Terrain Tires Colormatched Grill surround HomerTaco mesh grill insert Legacy "Toyota" Emblem Shrockworks plate rear bumper All-Pro plate front bumper w/ foglights All-Pro rock sliders Smoked Tail-lights DIY Steel Tailgate reinforcement Locking Tailgate handle Tint (15%) w/ sunstrip Tyger Tonneau cover (Removed) Bestop Soft Topper Bushwhacker colormatched fender flares DIY 8-ball shift knob DIY Amber LED grill lights DIY Debadged WeatherTech floormats Sudued US Flag door decals T-100 style tailgate decal Two way radio w/ 3' whip antenna Warn 8000lb winch CalTrend Neoprene seat covers DIY Bed tie-down anchors
    FWIW: I was considering installing OBA at one point. Did a lot of research into all the options. I came really close to buying the ARB twin compressor. After considering how often I would realistically use it though, I decided to go with a Viair 88p. I personally only hit the trails maybe three or four times a year and don't even air down every time, so it didn't make much sense for me to buy the expensive ARB setup, although it would be a whole lot cooler. I keep the 88p in an ammo can in the cab with an ARB tire repair kit. I've used it a lot more than I thought I would helping other people out of a bind; only used it to air myself up a handful of times. I love it though; super handy and arguably more convenient, as you don't have to move your entire truck close to air someone else up. You just connect it to the battery terminals and have at it. I have since bought two more for my other two vehicles. Best part is, it is a fraction of the cost of some of your other options; you could have almost seven of these for the price of just one ARB twin compressor, that doesn't include the cost (effort and money) of installation.
    Edit: I should add that the Viair 88p is not fast. If you need/want something that will air you up quick, this isn't it. It probably takes 2-3 min or so per tire to air up from 20PSI (33" tire). You also don't want it to overheat. You should let it cool down between tires. I would estimate that it takes about 20min or so to air up all four corners from 20PSI if you allow for cool down. Just rough estimates as I haven't aired up in awhile and never actually timed myself.
  16. Jan 31, 2022 at 8:20 AM
    TartanEagle
    TartanEagle Well-Known Member
    '17 ACLB 4x4 MT
    The ONLY thing I ever found good about wd-40 is that it makes for an excellent diesel starting fluid.
    Well, it also works well if you want to start something to rusting. It will promote rust faster than saltwater...
    As for this thread. I have both, an on-board compressor (mounted) and a small 10 lb (3000 psi) tank (mounted). I use the compressor most.
  17. Feb 3, 2022 at 2:11 PM
    21TacoTRDPRO
    ordnaS
    SoCal
    21 Tacoma TRD PRO
    Did you do the installation yourself?
  18. Feb 3, 2022 at 2:12 PM
    21TacoTRDPRO
    ordnaS
    SoCal
    21 Tacoma TRD PRO
    Yes I been doing some research into this
  19. Feb 3, 2022 at 2:14 PM
    21TacoTRDPRO
    ordnaS
    SoCal
    21 Tacoma TRD PRO
    I'm slowly changing my mind to go with the arb. And yes I wasn't including cost of re filling
  20. Feb 3, 2022 at 2:16 PM
    21TacoTRDPRO
    ordnaS
    SoCal
    21 Tacoma TRD PRO
    That's right. And some of these mounting points are pretty sweet. Like tucked in the bed of the truck or under the seat..the hood
