Power to a new lighted switch?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by EFG, Mar 16, 2023.
  1. Mar 16, 2023 at 7:39 AM
    EFG
    EFG [OP] Well-Known Member
    Eddy
    New England
    2022 Tacoma TRD Sport
    factory lift kit, Stinger Off Road Stereo, Customized leather interior, Backflip X4S Tonneau,
    Hey All,
    I had no idea how to try and search for the answer to this one.
    I was finally able to find an on off on switch for my backlit ditch lights.
    So the up opposition brings on the backlight,
    The middle position shut everything off and the down position brings on the ditch lights, which are actually a combo fog light
    It’s a lighted switch but if I tie it in to the Diode Dynamic harness or off the hot wire to the switch it will obviously stay on all the time.
    Can some one tell me where I can tie it in so that the switch light only comes on when all the other switches light up.
    Honestly it probably would have been good to wire the back light that way but I’m here now so I’ll live with it the way it is. It would give it all a nice factory look if I could get the switch to light up.
  2. Mar 16, 2023 at 8:03 AM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    Madimor, Stevie17 and Tacospike like this.
  3. Mar 16, 2023 at 8:55 AM
    EFG
    Eddy
    New England
    Why is it whenever you ask a question on here someone always has to direct you to another post?
    Not just simply give you an answer to the question.
    Thank you, I will look in to it but honestly it’s literally one wire. I can’t see buying another harness…It’s one splice in the right place to achieve my directive….
    I’ve gone down that (and many other) rabbit holes looking for answers.
    If you can show me where it is in that thread you posted I’d be really grateful because I did read through a bunch of stuff before I posted this question.
    Tons of lighting and wiring info but not THIS specific question and answer.
    One wire (the second wire goes to and is already on a good ground). Where is it? Which wire?
    02Duck likes this.
  4. Mar 16, 2023 at 9:11 AM
    Tacospike
    Two Trucks
    If you're left with one wire on the switch for illumination. Could run an add a fuse to the interior fuse box labeled 5A panel.
    There are adjacent switches to tap into but not sure which exact wire off the top of my head to tap.
  5. Mar 16, 2023 at 10:20 AM
    caribe makaira
    Caribbean, Puerto Rico
    It's not one wire. Read some more again. Get another hit from the hookah smoking caterpillar...
  6. Mar 16, 2023 at 11:28 AM
    EFG
    Eddy
    New England
    Yeah okay but your wrong and you offer no assistance….so thanks for that
  7. Mar 16, 2023 at 11:33 AM
    EFG
    Eddy
    New England
    Yes, that’s what I’m looking for the wire off the switch right next to new switch…
    I guess I could unplug the factory switch and check for voltage when the lights are on vs off.
    Then tap into that wire. The new switch light can’t draw much of anything so I could start with a fractional inline fuse I suppose.
  8. Mar 16, 2023 at 12:07 PM
    Tacospike
    Two Trucks
    I think the green wire on the cargo switch is what you're looking for. Check before tapping.
  9. Mar 16, 2023 at 12:12 PM
    caribe makaira
    Stop the guessing.:smack: Illumination is 2 wires.:rimshot:
    vicali and Tacospike[QUOTED] like this.
  10. Mar 16, 2023 at 12:24 PM
    shaggy135
    shaggy135 Well-Known Member
    Valley of the Sun, AZ
    2019 Barcelona Red TRD 4x4 OR DCSB MT
    So the illumination on that switch will be 2 wires. The positive will go to the green wire of the cargo switch. Then you should have a negative dim wire that will need to go on that cargo switch as well. If you use a chassis ground for illumination negative, then your switch won't dim at all.
    I used one of these harnesses and mine is a 2019 though. https://www.tacomaworld.com/threads...nd-play-switch-illumination-harnesses.697269/
    So maybe he can tell you the exact wires/colors he tapped into.
    Tacospike likes this.
  11. Mar 16, 2023 at 12:25 PM
    Tacospike
    Two Trucks
    Yes, from what I'm reading he has everything else intact just the backlit wire needing power. So ground and other wiring should be fine. Again, from what I have gathered and I may have misread it if not correct.
  12. Mar 16, 2023 at 1:03 PM
    caribe makaira
    (s) 2 wires for back lighting WITH the dash. As Shaggy sort of posted, the negative is for the selection part of the switch. It does nothing for the "illumination" side of the switch. There are 3 LED's inside that switch. ON - ON and switch illumination.
    Tacospike[QUOTED] likes this.
  13. Mar 16, 2023 at 1:08 PM
    skidooboy
    central lower mich
    Why is it when we post where to look for help, in the correct forum, and not spoon feed you the answer. In the forum where you may get more help, faster, instead of cluttering the main forum, people (like you) all get bristled up over it? I pointed you to the forum of your issue, where experts are there to help. and you did say, you didnt know where to look. I can see you didnt even try my link, by your comments because, it wasnt a link to a post, but, a WHOLE SUB FORUM ON LIGHTING AND WIRING. People there will answer this question but, usually stay out of the main 3rd gen forum messes.
    Wow we are doomed as a species, when you cant be bothered to help yourself. I do wish you good luck. Ski
    mic_sierra, Chew and caribe makaira like this.
  14. Mar 16, 2023 at 1:55 PM
    EFG
    Eddy
    New England
    Thanks, go help someone else that will appreciate you.
  15. Mar 16, 2023 at 1:58 PM
    shaggy135
    No need to be rude. You did ask for help and you got it from multiple people. Sorry if we want you to do your own research. We are all adults here.
  16. Mar 16, 2023 at 2:15 PM
    Martian__
    Martian__ Well-Known Member
    Southern California
    Doesn’t leave much to be desired by the way the OP responds.
  17. Mar 16, 2023 at 3:06 PM
    stuttgart1
    stuttgart1 Well-Known Member
    2019 TRDOR
    This is definitely entertaining.
    Kwikvette and EFG[OP] like this.
  18. Mar 16, 2023 at 3:46 PM
    6MTPro
    6MTPro Well-Known Member
    HI -> CA
    2018 TRD Pro 6MT | 2004 4Runner 4.7 V8
    Tune, 285/75/16, Diode Dynamics, PPF, Bakflip Mx4, Meso, Cali Raised, TJM
    two wires one to your 12v power supply and one on a fuse tap for illumination. I have the same switch and lights for my ditch lights.
    EFG[OP] likes this.
  19. Mar 16, 2023 at 5:45 PM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    My favorite was when he shot down the plug and play harness that makes what he’s asking for a cake walk
  20. Mar 17, 2023 at 7:32 AM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    I thought it was particularly clever to tell caribe that he doesn’t know what he’s talking about.. :D
