Power to bluetooth upgrade for 2007 Taco (dbl cab)
Discussion in 'Audio & Video' started by PatriotTaco, Oct 9, 2018.
  1. Oct 9, 2018 at 9:50 AM
    PatriotTaco
    PatriotTaco [OP] Member
    Pablo
    2007 TRD Taco Indigo Ink
    none
    Just got a Tranzit BLU HF for my rig. Hoped to easily find a red & black to connect the unit to acc power, but all I see are harnessed plugs, and all the YT vids don't show the actual process of splicing into those. Not an electrical engineer, so as little use of a multimeter (if any!) would be appreciated; I WILL put on my big boy undies if needed, but.... Really just looking for a quick, "clip here, attach there, etc...". And major bonus if there's pics! Thanks y'all!
  2. Oct 9, 2018 at 10:26 AM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    Easy place to get accy power and a good ground is in the cig lighter down below the radio.
    Use a phone charger or something to ensure it turns off with the truck, but I'm pretty sure it does.
    The white/black wire is always ground in toyota.
    Edit* I like the cig lighter better than the accy wire in the radio harness because that wire is very thin, and has a very low amperage available. Hooking up the transit to that wire for power could blow a fuse.
    The cig lighter is fused for something like 15-20 amps so no concern of drawing too much power there.
    PatriotTaco[OP] likes this.
  3. Oct 9, 2018 at 10:42 AM
    PatriotTaco
    Pablo
    none
    Awesome! Thx! What has to come out to get at lighter socket? Trying to minimize removal of panels...
  4. Oct 9, 2018 at 10:52 AM
    destin_meeks
    Destin
    Tuscaloosa, AL
    I feel like after you pop off the A/C panel and take the radio out, it’s pretty easy to reach down there and unplug the connector from the socket.
  5. Oct 9, 2018 at 12:59 PM
    PatriotTaco
    Pablo
    none
    Is there a socket at each receptacle? Or one main one? If that's the case, I can't get my fat fingers back there. Think I'm in over my head.
  6. Oct 9, 2018 at 1:48 PM
    PatriotTaco
    Pablo
    none
    Is all gray wire accy?
  7. Oct 9, 2018 at 1:49 PM
    destin_meeks
    Destin
    Tuscaloosa, AL
    yes. the super thin grey wire
  8. Oct 9, 2018 at 2:05 PM
    PatriotTaco
    Pablo
    none
    Thx so much! Totally in the dark on this, can I just splice into any available dash hanger, the one that goes into the AC/heat has a gray?
  9. Oct 9, 2018 at 2:37 PM
    destin_meeks
    Destin
    Tuscaloosa, AL
    NO!! Just because it’s grey doesn’t mean anything. In the main radio harness, the thin grey wire is accy. This is the only wire I would even attempt getting power from. I definitely wouldn’t mess with wiring going to ac controls.
  10. Oct 9, 2018 at 2:49 PM
    PatriotTaco
    Pablo
    none
    Gotchoo! Think I'm going that route(main radio harness); may adjust if it blows fuses. What should I use to splice? Any particular connectors/technique you recommend?
  11. Oct 9, 2018 at 3:59 PM
    destin_meeks
    Destin
    Tuscaloosa, AL
    Nothing better than a good ol' fashion military splice
  12. Oct 9, 2018 at 10:12 PM
    PatriotTaco
    Pablo
    none
    YA BUDDY!!!!! Done and done! It works, sounds awesome, no extra parts....so so so so so STOKED! Can't thank you enough for nudging me away from potential mistakes, and worse yet, quitting. Mahalo
    destin_meeks likes this.
  13. Oct 10, 2018 at 5:02 AM
    destin_meeks
    Destin
    Tuscaloosa, AL
    :thumbsup:
