Power tool kit help!
Discussion in 'Off-Topic Discussion' started by Masada, Feb 10, 2010.
  1. Feb 10, 2010 at 7:46 AM
    Masada
    Masada [OP] Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    Ok so I'm closing on a house today and I need some advice on some basic hand tools. I'm a total noob when it comes to this stuff, so I don't want to buy some really crappy stuff, but at the same time I can't afford a $200 drill.
    I've been looking at cordless stuff and notice the volts are all different. Are higher volts better than lower? IE 17.5V vs. 19.2V...
    stuff I'm looking at:
    http://www.sears.com/shc/s/p_10153_...s&cName=Portable+Power+Tools&sName=Combo+Kits
    http://www.walmart.com/ip/Black-Decker-18V-4-Tool-Combo-Kit/9714679
    http://www.lowes.com/pd_36099-79992...rentURL=/pl_Combo+Kits_4294857540_4294937087_
    http://www.lowes.com/pd_39443-79992...RL=/pl_Combo+Kits_4294857540_4294937087_?No=0
    http://www.homedepot.com/Tools-Hard...splay?langId=-1&storeId=10051&catalogId=10053
  2. Feb 10, 2010 at 7:49 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Personally, I would get an ABS sensor for a second gen first. :p
  3. Feb 10, 2010 at 7:54 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    Out of all the kits you have listed, If it was me, I would be going with the porter-cable Lithium Ion kit. Although it costs more, you will be getting a much higher quality kit, and the batteries will last quite a bit longer than the NiCd. If you are one that will take care of your tools, they should last you quite a long time.
    The higher the voltage, generally the more power you will be getting out of the same tool. You will also not need to work the tool quite as much to get the same result. 18v is now pretty much the industry standard. For commercial work you can even get 36v cordless stuff, but that would be pointless for your application. As for the Ryobi stuff, it will get the job done, but for how long? You get what you pay for, as with most things in life.
  4. Feb 10, 2010 at 7:56 AM
    MAXTacoma
    MAXTacoma Well-Known Member
    Lexus GS 350
    It depends on what you plan on doing with your drill. The smaller volt drill tend to be lighter and easier to hold over a longer period of time but they dont have as much power or battery life as the larger volt drills. If you aren't going to use it that much then I would just suggest buying one of the cheaper drills...
  5. Feb 10, 2010 at 7:56 AM
    doug355r
    doug355r Well-Known Member
    Chandler, AZ
    07 Tacoma TRD Sport
    TRD intake, TRD exhaust, Stereo, Step Bars, Electric bed cover
    I can tell you this...don't get the black and decker. I have one and it feels like a toy.
    I would go with the Ryobi or the Craftsman
  6. Feb 10, 2010 at 7:59 AM
    Masada
    Taylor
    Laveen, AZ
    That's not what tax credits for buying a house are for. Besides, Scott and I have worked out a solution unless you know something I don't?
    Thanks SC, that helps out...like I said, I'm a total noob when it comes to this stuff, I just don't want to buy something crappy but at the same time I don't need something that a home builder is going to use everyday.
