Power upgrades with out S/C
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bledsoe3, Sep 1, 2015.
  1. Sep 1, 2015 at 8:46 PM
    #41
    caplew
    caplew New Member
    Scott
    CA
    01 Taco
    I have a new in box TRD SC for 4.0L sitting in my garage...On the fence to install it or sell it.
  2. Sep 1, 2015 at 8:53 PM
    #42
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
  3. Sep 1, 2015 at 8:54 PM
    #43
    twalchlii1
    twalchlii1 Tacotraitor
    Tom
    Wa
    2018 GC Trailhawk
    Are floor mats a mod?
    If ur towing with a Taco, what you want is gears. Without an SC you just can't get enough power without a V8. Yes you will go a bit slower up the hills but not a 4500 rpm. Also you will be able to beat a Geo metro 0-60. Otherwise, maybe a Tundra? Yeah, I know your are supposed to be able to tow like 4500 with a taco but that's on a flat with a tailwind. Reality is that about 2500 is max for comfort on hills and stuff.
  4. Sep 1, 2015 at 9:02 PM
    #44
    Justinlhc
    Justinlhc Not looking for a relationship
    Mine says 6500. I'd never try it, though.
  5. Sep 1, 2015 at 9:14 PM
    #45
    Yota64
    Yota64 Professional Threadjacker
    That sucks. Why can everyone else make mods then? Or is that just for chargers?
    That BLOWS. I would want some $$$ back...
    Agreed on gears. Also, 6500 lbs with tow package. I wouldn't do that above 55 MPH though
  6. Sep 1, 2015 at 9:14 PM
    #46
    Mavrick
    Mavrick Well-Known Member
    2015 DCSBOR
    If I get a boat that weighs around 3500 pounds with trailer and I going to be able to do 70 down the freeway in 5th gear no hills/wind or am I going to have to drop it down to 4th gear?
  7. Sep 1, 2015 at 9:23 PM
    #47
    Yota64
    Common sense would tell me yes, as long as you drop it in 4th for any type of grade so that it doesn't hunt. However, even with momentum and flat road, your engine load is significantly higher in top gear. I know this because of the ultragauge. It is probably better to be in higher RPMs.
  8. Sep 1, 2015 at 9:29 PM
    #48
    twalchlii1
    Tom
    Wa
    2018 GC Trailhawk
    Maybe 6500 per the suspension ( doubtful) but this is my 3 rd Taco towing a 2700 lb tent trailer, and I sure wouldn't want to do any hill or grades with that much weight. Still, they are awesome trucks.
  9. Sep 2, 2015 at 10:10 AM
    #49
    bledsoe3
    bledsoe3 [OP] Well-Known Member
    Portland
    '15 DCLB Limited
    SnugTop, Air Lift bags, Bilstein 5100's up front, AAL in rear, 275/70/18 BFG AT TA KO2, URD TCAI, URD Cat Back
    Starting with the URD TCAI and MAF CAL. Should be here in 5 days. If the dyno charts are correct it looks like 15+ hp.
    I guess exhaust is next.
    Does the throttle body adaptor and larger throttle body help at all, or just use more gas?
  10. Sep 2, 2015 at 10:36 AM
    #50
    Thomas Jefferson
    Thomas Jefferson Keyboard Warrior
    Sacramento,CA
    '13 SR5 DCSB 4x4
    One can never have too many light bars.
    I think you can install a manifold spacer.
  11. Sep 2, 2015 at 10:39 AM
    #51
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    Unless you get into cams, nothing. All the rest will not give any dyno increase. Some will move around the torque, but no real HP increase.
    Justinlhc likes this.
  12. Sep 2, 2015 at 10:40 AM
    #52
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    More hashbrowns
  13. Sep 2, 2015 at 10:48 AM
    #53
    Justinlhc
    I was told a 65whp increase from just an exhaust. :rofl:
  14. Sep 2, 2015 at 10:49 AM
    #54
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    Pancake inductor mod. With or without the scooter stick. Intercool it and you'll see gains in the tweens.
  15. Sep 2, 2015 at 10:56 AM
    #55
    Justinlhc
    K&N filters are good for 45rwhp. You don't even need to install the filter. Just the sticker.
  16. Sep 2, 2015 at 4:45 PM
    #56
    Yota64
    I don't even think it's the suspension. It's the drive train. I have no doubt though that it's no fun! I'd get a full size to tow that much.
    What do you do with the cams?
    Also, urd has a naturally aspirated power package that claims 50 hp.
  17. Sep 2, 2015 at 4:57 PM
    #57
    Justinlhc
    That's actually pretty impressive, but at $3k+ it doesn't come cheap.
    Isn't that almost what the TRD S/C guys are getting? :laugh:
  18. Sep 2, 2015 at 5:02 PM
    #58
    dmharvey79
    dmharvey79 Well-Known Member
    Dennis
    Northern Virginia
    A 2015 F-150 with the 2.7L EcoBoost and the EcoBoost Payload Package, done. The OP's needs are asking a lot from any mid-size truck. Just my two cents...
  19. Sep 2, 2015 at 5:02 PM
    #59
    Yota64
    68 actually. The package is supposed to be an alternative to an sc. But somehow I think the sc is funner even if these mods gave 68? Probably because of the tq curve. But I don't fully understand differences between open throttle gains and closed loop gains. Maybe someone could tell me.
  20. Sep 2, 2015 at 5:36 PM
    #60
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    All those in the kit make it drive like a Honda...... It's just too free flowing
