Power Washer Recommendations
Discussion in 'Detailing' started by bonifacio, Jun 12, 2019.
  1. Jun 12, 2019 at 2:23 PM
    bonifacio
    bonifacio [OP] Well-Known Member
    Central PA
    2019 Cement Gray Tacoma OR 4x4
    Wanted to pick one up for no other reason than washing the Tacoma. Any recommendations?
  2. Jun 12, 2019 at 2:26 PM
    Pruby18
    Pruby18 Well-Known Member
    2019 DCSB OR 4X4
    I was literally about to make a post for this. I want one that can do the foam blasting thing or whatever it’s called.
    Gunshot-6A likes this.
  3. Jun 12, 2019 at 2:27 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    They make foam blasters for regular garden hoses too.
    LordIsGod likes this.
  4. Jun 12, 2019 at 2:36 PM
    bonifacio
    Central PA
    I kind of felt stupid for posting. But figured this would be the best place to get a standard one that won't strip off all the paint. Lol.
    So yeah... I don't even have a garden hose. List of things I need to get around to.
    Gunshot-6A[QUOTED] likes this.
  5. Jun 12, 2019 at 2:37 PM
    Gunshot-6A
    Conner
    Everett, WA
    I'd get you a garden hose before you look for a power washer.
  6. Jun 12, 2019 at 2:39 PM
    Clearwater Bill
    Billy
    Largo Florida
    Will come in handy to feed the power washer. :thumbsup:
  7. Jun 12, 2019 at 2:40 PM
    FFBlack
    FFBlack Well-Known Member
    2019 TRD OFF ROAD
    I recently bought a Mi T M commercial power washer and I'm loving it. It has the Honda commercial gas engine and plenty of power. Quick connect hose and no flat tires.
    ace96 likes this.
  8. Jun 12, 2019 at 4:16 PM
    bonifacio
    Central PA
    Should probably just change your name to HAIRYRICHTACO.
    freddy2923 likes this.
  9. Jun 12, 2019 at 4:24 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    One like this with an AR pump? I've had one for over 10 years. Sears sold these branded as a Craftsman at 3,000 PSI. They had a sale price at $399. Couldn't pass it up.
    FFBlack[QUOTED] likes this.
  10. Jun 12, 2019 at 4:36 PM
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Kings, 275/70/17, a few custom items, lots of Meso mods.
    Just be careful with a pressure washer if you're going to use it on your truck paint. You can actually push really fine pieces of dirt and debris into automotive paint and Toyota's is fairly soft. Just use low pressure. I only foam and hand wash but pressure was the bed and underside every once in awhile.
    CS_AR likes this.
  11. Jun 12, 2019 at 4:40 PM
    FFBlack
    2019 TRD OFF ROAD
    20190612_174309.jpgIts buried in my shed right now but looks close. This thing is a beast
    CS_AR[QUOTED] likes this.
  12. Jun 12, 2019 at 5:00 PM
    CS_AR
    That's it. I looked at mine again and it's only a 3,000 model. Sometime when you really need to get down on something like a sandblaster, get a turbo attachment. You can bore holes in wood and concrete with one of those. Don't use it on brick. It will blow away the concrete between the bricks.
  13. Jun 12, 2019 at 5:02 PM
    CS_AR
    Same here. The foam dispenser works on the lowest pressure setting that's about like a car wash. I use it for under the car and wheel wells.
    20tacoma17[QUOTED] likes this.
  14. Jun 12, 2019 at 5:46 PM
    gorram
    gorram Well-Known Member
    2016 Limited
    Any cheap electric pressure washer will have decent enough PSI to wash a car. Try to opt for GPM over PSI when comparing models. What sucks about the cheap electrics is the hose, gun and wand are generally shit. Upgraded hose (longer go for 50' min, wont kink to shit) and gun will be more expensive than the whole setup but is worth it and will outlast cheap or expensive pump units. Many of the cheap brands will need adapters to work with decent hose/gun (MTM, Mosmatic etc). I think Ryobi and Greenworks are two brands that adapt right over to a decent hose. Obsessed Garage on youtube has some videos of the common models.
    Some foam cannons will require you to swap out to the smaller orifice if using one of these cheap electrics. A gas machine would want the larger orifice. Obsessed has this on his website I believe. He will have the adapters if you've already got a SunJoe or other model that need adapters.
    geoyota760 and 20tacoma17 like this.
  15. Jun 13, 2019 at 6:07 AM
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    That would be a foam gun where as pressure washer is a foam cannon. Cannon will make way more suds versus the gun.
  16. Jun 13, 2019 at 8:08 AM
    FFBlack
    2019 TRD OFF ROAD
    I saved up and looked at bunch of these for years. No riches here .I paid more to get a unit that lasts instead of a disposable plastic unit that is a piece of crap from the start. I'm a firm believer in buy once cry once. Besides I'm rocking a 16 Taco Mr .2019.
  17. Jun 13, 2019 at 7:32 PM
    Babybluetaco
    Babybluetaco Well-Known Member
    Austin
    Monroe, North Carolina
    09 5 lug
    I have a generac with speed wash 3000 psi. eBay foam cannon
    pudge151 and 20tacoma17 like this.
  18. Jun 15, 2019 at 7:34 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    If you are wanting to get a foam cannon many of them require over 2.0gpm on a pressure washer.
    I’m a fan of gas. Electric is just a PITA. But either works just pay attention to the GPM. I’m finding this typically means buying medium duty pressure washer or higher.
  19. Jun 17, 2019 at 11:51 PM
    runner05
    runner05 Well-Known Member
    Karl
    I've had a Ryobi for 4 years now and it works great.
    GasPowered likes this.
  20. Jun 18, 2019 at 9:06 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    Gas or electric?
    Get at least 1.6 GPM and 1200 PSI
    For the price ryobi makes a good gas unit and Kärcher for electric.
    Get the $20 MATCC (or something like that) amazin foam cannon, you may need a special adapter for your brand powerwasher.
    For a hose, I can't believe you don't have a hose lol, I LOVE my Zero-G hose. So much so, I have 2, 50ft and 100ft.
    You will also need some decent car wash products, 2 buckets and 2 grit guards, and a bunch of wash mitts.
    I have a karcher electric and its perfect for car washes and small projects.
    For the foam gun. Chemical guys maxisuds2 is a great and inexpensive soap. An once or 2 added to the foam dispenser that you've prefilled with hot water will foam up like crazy.
    ace96 likes this.
