Power washer
Discussion in 'Detailing' started by Manwithoutaplan, Mar 27, 2016.
  1. Mar 27, 2016 at 7:02 PM
    Manwithoutaplan
    Manwithoutaplan [OP] the full Monty
    ID
    So i been looking into power washer to wash off the off road quads and truck. So i have read about the different pumps and it looks like
    Pump Type Commercial-grade triplex is the better of the pumps. The other pump is a Axial cam. what engine should i look into. IS there anything else i need to look into.
    Any insight would be gratefully help full, on what type of power washer i should look into. my Range is about 300 to 600 range.
    Here are the one i am looking at.
    SIMPSON Aluminum 3200-PSI 2.5-GPM Carb Compliant Water Gas Pressure Washer
    Troy-Bilt 3000-PSI 2.7-GPM Carb Compliant Cold Water Gas Pressure Washer
  2. Mar 27, 2016 at 7:18 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Troybilt would be my choice of the 2.
    PSI means little if you aren't pushing enough GPH.
    3200 at 2.5 is not as good as 3000 at 2.7, IMO.
  3. Mar 27, 2016 at 7:53 PM
    Manwithoutaplan
    ID
    What about the pump though? Axiel pump you can not fix if it breaks and triplex pump you can actually fix.
  4. Mar 27, 2016 at 7:55 PM
    T4RFTMFW
    Forgot about that.
    Repairable/replaceable pumps FTMFW.
    FWIW we've used a Husqvarna for yeaaaars and it's still kicking ass without any issues and commercial use.
    I can get you a model number Friday if you want. Similar PSI/GPH.
  5. Mar 27, 2016 at 7:56 PM
    Manwithoutaplan
    ID
  6. Mar 27, 2016 at 8:01 PM
    Manwithoutaplan
    ID
    What things are cleaning with?
  7. Mar 27, 2016 at 8:08 PM
    TackleMeElmo
    TackleMeElmo Well-Known Member
    desch
    silverado 1500
    Anything over
    2200 is OD for cleaning
    Trucks
    And quads. Unless youre cleaning large surface areas with attachments
    You really
    Dont need those
    3k badboys. Outta those two though id pick the first product because of the compact build
  8. Mar 27, 2016 at 8:09 PM
    T4RFTMFW
    Used for anything and everything, but used professionally for commercial and residential needs of any kind.
    Grounds, buildings, RVs and motor homes, whatever.
  9. Apr 4, 2016 at 3:06 PM
    T4RFTMFW
  10. Apr 8, 2016 at 8:10 PM
    TackleMeElmo
    desch
    silverado 1500
    Alot of people who buy these four wheelies regret it. Those little guys are a Hassle and oftentimes end up breaking leaving you with an off balance frame and shaky set up (vibrating around on the surface, espeically if theres aby incline)
    Design is a big thing with these powerwashers...save yourself the trouble in the future and get one like this http://m.lowes.com/pd/SIMPSON-Alumi...-Compliant-Water-Gas-Pressure-Washer/50119895
    Or atleast something with a similar design even if ts 1000psi less
  11. Apr 8, 2016 at 8:13 PM
    TackleMeElmo
    desch
    silverado 1500
    Oh by the way i putchased my powerwasher primarily for do Ng hardscape restoration so i fou d myself "off roading" with it pretty normally and running it on slight inclines. I also use it for washing a bunch of random stuff but i wanted to qualify why im pushing design so much
  12. Apr 8, 2016 at 8:14 PM
    T4RFTMFW
    Easier, sure. But this one has been used and abused for years without complaint, even when I have to pull the wheels for it to fit in the truck every time.
    Non issue for me.
    TackleMeElmo likes this.
  13. Apr 8, 2016 at 8:15 PM
    TackleMeElmo
    desch
    silverado 1500
    Price point and purpose @op!! All ya can do really...
  14. Apr 8, 2016 at 8:21 PM
    WarrenG
    WarrenG Well-Known Member
    I have a little karcher electric. Its like 1200 psi, more than enough power to push that dirt farther, so you will never actually get it clean. Cant stand a loud gas motor running constantly.
  15. Apr 8, 2016 at 8:22 PM
    T4RFTMFW
    Truth.
    The only real ding I have on that Husq is that for some people, if they have to lift it by themselves that could be an issue.
    It isn't lightweight. It is a commercial grade machine though and has kicked ass for us, would recommend it. I don't have any other experience with other mobile pressure washers. Our other commercial machine is far more complex and my sidewalk cleaner is an electric model my parents bought back in the day.
  16. Apr 8, 2016 at 8:30 PM
    Manwithoutaplan
    ID
    :popcorn: great points here.
  17. Apr 8, 2016 at 8:31 PM
    Manwithoutaplan
    ID
    I ended up getting this washer ^
    T4RFTMFW likes this.
  18. Apr 8, 2016 at 8:34 PM
    T4RFTMFW
    If you want to really nerd out, an adjustable pressure wand is like heaven.
  19. Apr 8, 2016 at 8:37 PM
    Manwithoutaplan
    ID
    I believe i do have adjustable wand with max to min.
  20. Apr 8, 2016 at 8:43 PM
    Manwithoutaplan
    ID
    it is called Dial- a -wash I guess :notsure:
